Old 03-17-2011, 12:12 PM   #16
I overfill them and clean the excess after assembly and after the first couple runs so there's the absolute minimum amount of air possible inside the diffs.
How will you know the air/oil ratio if there's "x" amount of air inside? and thus...
How will you know your resultant resistance of that "unknown mix"?
Anal? you bet!
It does the same exact thing as having air inside the shocks.
The air expands when hot more than the oil thus the pressure is higher all the time, instead of for a while until it leaks the excess, so the diffs are even more prone to leakage.
xe
If your friends don't listen, get new friends
Cheap and fast, not reliable - Cheap and reliable, not fast - Reliable and fast, not cheap
maxflo777 is offline   Reply With Quote
Old 03-17-2011, 12:14 PM   #17
kaptain crash's Avatar
Trader Rating: 32 (100%+)
Send a message via Yahoo to kaptain crash
Originally Posted by morgoth View Post
To the top is too much. Diffs will leak easier and the oil will come out of everyhole when you're puttin it together.
Lutzinator had a nice tutorial on his website. This is how most people fill their diffs, and it's the best way imo.
http://lutzinator.com/?page_id=80
Originally Posted by tc5 man View Post
some manuels of diffrent manfacters tell you to ethier fill the oil below the gear and just over the crosspins .
or fill to the top of the gears not compeltely filling the diff you whould be asking for a bad leak
Originally Posted by token View Post
Even Lutz used the term: perfectly full
They ...both...wiped the top of the ...top... gear to make it...perfectly full.
YEAH IM OLD...RUSTY AND SLOW,CRASH A LOT TOO. BUT WITH NITRO I HAVE A BLAST!
kaptain crash is offline   Reply With Quote
Old 03-17-2011, 01:29 PM   #18
My friend and I just started using our shock pumps on our diffs. It was for fun and to experiment but I always get one monster bubble out from below the gears!
Kane-o is offline   Reply With Quote
Old 03-17-2011, 02:25 PM   #19
Trader Rating: 68 (100%+)
Originally Posted by razo125 View Post
If you completely fill your diffs with no air the diff will bind in longer mains when the oil heats up and expands. Your diff could even possibly hydrolock.
You're not going to hydrolock a diff.... The seals or O-rings would blow.
Greg B is offline   Reply With Quote
Old 03-17-2011, 02:37 PM   #20
rangerjkb's Avatar
Trader Rating: 38 (100%+)
Send a message via MSN to rangerjkb
Recommend filling to manufacturers specifications, as this is what is used/tested and put into the instructions for best performance.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
NEW AGAMA A8 BUGGGY rc_cal Nitro Off-Road 10213 07-13-2016 12:30 PM
Jammin X1 - so close yet so far beetlebz Nitro Off-Road 4524 03-25-2012 01:54 PM
Diff oil? rcdude236 Nitro Off-Road 20 05-13-2010 12:41 AM
