Diff rebuild question >
Old 03-15-2011, 04:53 PM
Trader Rating: 26 (100%+)
Default Diff rebuild question
Okay, I just rebuilt my front diff in my Losi 8T 2 and I used 7000 Associated Diff oil. This is all my LHS had, they were out of the Losi 7k weight so I picked the Associated stuff. Are these the same or should I have chose a different weight since I went with Associated?
Question 2: What does it mean when I spin the diff and you can feel the gears spinning on each other. Everything is back together how it is supposed to be, but I've never done this before so I am not sure if this is normal to feel this.
Thanks in advance
SDelaney is offline
Old 03-15-2011, 05:07 PM
DiZzYNaTiOn's Avatar
Trader Rating: 25 (100%+)
Question one, there pretty much the same you'll be fine
Question two, is it a grinding? They should be smooth. Move the wheels in opposite direction there should be no bumps.
DiZzYNaTiOn is offline
Old 03-15-2011, 05:16 PM
rider313's Avatar
Trader Rating: 94 (100%+)
Aslong as there is no binding or grinding you should be good on number 2. there is a losi 8ight T 2.0 thread. Post in there for any questions you have with your 2.0 instead of creating a whole new thread. We will be happy to help you in any way.
rider313 is offline
Old 03-15-2011, 05:29 PM
Ok, I will post there going forward... Its hard to explain the feeling, it doesn't bind but I can feel the gears spinning as I turn it. I wonder if it just has to do with the thicker fresh diff oil. Before it had just the stock fill from the 8T RTR kit.
All teh gears looked good when I cleaned it and they all seated properly when putting it back together.
SDelaney is offline
Old 03-15-2011, 05:38 PM
rider313's Avatar
Good deal. And what you are describing sounds like a normal diff with fresh fluid.
rider313 is offline
Old 03-15-2011, 05:52 PM
Wait, pick your rear-end or front (which ever one) up and grab both wheels, rotate tires in opposite directions,
Do you feel any vibrations or even the smallest amount of grinding?
If so you need to check it out now before you drive it and blow out a diff.
Old 03-15-2011, 07:19 PM
I haven't gotten it all back together yet, but I will do this tomorrow when I put it all back together... If there is any grinding - what would be the cause? Is it possible to tighten the diff housing screws down to much?
SDelaney is offline
Old 03-15-2011, 07:28 PM
Possibly something fell in it while administering the diff oil, I had a peice of decal sticker in mine once years ago and the next time i took it apart the oil had turned yellow from the sticker and was really thick, some sort of reaction happend.
Possibly a peace of gasket broke off and fell in
But, like you said it might be fine, test it out and report back, its better safe the sorry.
Old 03-15-2011, 08:32 PM
Its normal to feel alittle clicking when holding the diff in your hand and spinning the cups in opposite directions. If you feel a bind or grinding than something may be wrong. You can't over tighten the screws. They need to be tight but don't strip them.
bacchus is offline
Old 03-16-2011, 12:09 AM
Always make sure the o-ring seal and paper gasket is intact. No way you can over tighten. There should be no grinding, if so you assmbled wrong or something has fallen in, like a piece of gasket. Re open, re asemble and see if still grinds.
Dave1GP is offline
Old 03-16-2011, 08:02 AM
The one thing I don't see in the exploded view is, there are the 4 flat metal pieces that sit at the end of the pins. These have a rounded side and a flat side. Does it matter which direction they go in? Right now I have it with the flat side at the top toward the ring gear.
When I get home from work I will tear it all apart again.
SDelaney is offline
Old 03-16-2011, 09:30 AM
Also take some picks if your tearing down again, of inside of diff. and post them here
Old 03-16-2011, 10:04 AM
Stanton's Avatar
Is this the type of diff you have? If so it's the heavy duty diff cup. The round ends of the metal inserts go down in the cup and the beveled sides go toward the cup. If you didn't put the beveled edges toward the cup, they will not seat correctly and will cause binding of the diff gears. Sounds like that could be the problem...
Stanton is offline
Old 03-16-2011, 10:13 AM
token's Avatar
if you have a standard diff cup, you need to make sure the gear are in correctly.
There are 2 different depth grooves in the cup.
Insert the the gears in the long slot first. The gears in the shorter slot will be on top.
If these are in wrong, the diff will lock up on you.
token is offline
Old 03-16-2011, 11:16 AM
That is my DIFF and I didn't notice the beveled edge before, so this may be it. Man, guess I need to pay more attention to those little details.
I will report back tonight.
SDelaney is offline
