Diff rebuild question
Okay, I just rebuilt my front diff in my Losi 8T 2 and I used 7000 Associated Diff oil. This is all my LHS had, they were out of the Losi 7k weight so I picked the Associated stuff. Are these the same or should I have chose a different weight since I went with Associated?
Question 2: What does it mean when I spin the diff and you can feel the gears spinning on each other. Everything is back together how it is supposed to be, but I've never done this before so I am not sure if this is normal to feel this.
Thanks in advance
Thanks in advance
Aslong as there is no binding or grinding you should be good on number 2. there is a losi 8ight T 2.0 thread. Post in there for any questions you have with your 2.0 instead of creating a whole new thread. We will be happy to help you in any way.
Ok, I will post there going forward... Its hard to explain the feeling, it doesn't bind but I can feel the gears spinning as I turn it. I wonder if it just has to do with the thicker fresh diff oil. Before it had just the stock fill from the 8T RTR kit.
All teh gears looked good when I cleaned it and they all seated properly when putting it back together.
Good deal. And what you are describing sounds like a normal diff with fresh fluid.
Possibly a peace of gasket broke off and fell in
But, like you said it might be fine, test it out and report back, its better safe the sorry.
Its normal to feel alittle clicking when holding the diff in your hand and spinning the cups in opposite directions. If you feel a bind or grinding than something may be wrong. You can't over tighten the screws. They need to be tight but don't strip them.
Always make sure the o-ring seal and paper gasket is intact. No way you can over tighten. There should be no grinding, if so you assmbled wrong or something has fallen in, like a piece of gasket. Re open, re asemble and see if still grinds.
The one thing I don't see in the exploded view is, there are the 4 flat metal pieces that sit at the end of the pins. These have a rounded side and a flat side. Does it matter which direction they go in? Right now I have it with the flat side at the top toward the ring gear.
When I get home from work I will tear it all apart again.
if you have a standard diff cup, you need to make sure the gear are in correctly.
There are 2 different depth grooves in the cup.
Insert the the gears in the long slot first. The gears in the shorter slot will be on top.
If these are in wrong, the diff will lock up on you.
Is this the type of diff you have? If so it's the heavy duty diff cup. The round ends of the metal inserts go down in the cup and the beveled sides go toward the cup. If you didn't put the beveled edges toward the cup, they will not seat correctly and will cause binding of the diff gears. Sounds like that could be the problem...
I will report back tonight.
