Old 03-14-2011, 09:49 AM   #1
Trader Rating: 26 (100%+)
Default Tips for jumping jumps with steap faces
So they recently redesigned my local track and as it stands now the faces to all the jumps are very steap. I have not gotten to throw any laps down on it yet, but setup wise should I change anything? How about driving and approach to the face of the jump.
It looks like they are so steap that you'll bottom out if you approach to fast.
I hope to get some practice in friday, but was wondering if I should increase/decrease ride height, stiffer or softer shock oil, etc.
☆ Losi 8T 2.0 ☆ OS Engines ☆ VP PowerMaster ☆ AKA ☆ HiTech ☆ F-Bomb Graphix ☆
555 Raceway, Bartow FL - http://www.facebook.com/555Raceway - Be a part of the rebirth!
SDelaney is offline   Reply With Quote
Old 03-14-2011, 12:06 PM   #2
AZRC4Me's Avatar
You should have a baseline setup for your local track. Try that and adjust accordingly.
You will not get much useful advice on here when you post no pictures of the track, what buggy/truggy you run, tires that work, etc. There is so much that goes into a setup, it's not like someone can come on here and go "oh, steep jumps, run setup x". Find something that works for you by making one small change at a time. And make sure you're running the right tires before you start turning wrenches.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Old 03-14-2011, 12:14 PM   #3
Thanks. I usually run the Adam Drake Silverstate setup for my 8T 2.0. Tires I am thinking of running calibers and if not hooking up going with the Gridiron Mediums.
Sorry, but I didn't get pics.
