Bashers: How often do you change your diff oil?
I just went to a full viscous diff setup today and I am curious to know how often you change the oil? I never race, only bash, so top performance 100% of the time is not on my agenda. Would it be safe to change like once ever 2 gallons of fuel?
TIA
TIA
Depeding on what vehicle, you will be fine. Some cars diffs leak, so you will have to watch for that. Most 1/8 diffs you should be able to get away with probably 5 gallons if not more if you just plan to bash.
for my race buggy, every month(only race once a month).
for anything useally when i brake a diff housing or something.
Takes me about 3 hrs or more. but when I clean my diffs, they get cleaned till they look like they just came out of the bag of a BN Kit. Course I have no compressor just tooth brush and simple green, dish soap, and maybe denatured alcohol if i feel like spending 20 dollars on the gallon, and another 15-20 on another gallon of simple green.
Quick and simple way to get the diff spotless inside. Take a zip lock baggy put the diff housing in it seal it almost completely and stick the straw of the wd40 can in there and blast em out. takes less 1 min to get the inside clean. and all the mess is left in the bag. then just reassemble it with fresh fluid and your good to go. Also you might want to pull the o rings out before you spray the WD40. some times they dont get along.
Another way to get the oil out is to put the complete diff upside down on a kitchen sponge. (with the rough green side)
The sponge wil suck out the oil in a few minutes.
A good rule of thumb is to change diff oils after each gallon of fuel in order to optimize performance.
