CLEANING YOUR 8TH SCALE BUGGY?
lol, ya I remove all electronics/motor and hose her down. I use a quality motorcycle bike wash as its safe for plastic's and anodized parts and use a toothbrush, hose her down again. spray a vinyl conditioner on her (303) and air it off. I also use to final spray it with mop and glow and then air hose it down.
just did this last weekend
- strip chassis of engine/pipe and electronics tray.
- Simple Green and small brush everything
- hose it down with running water was so filty I wanted to make sure all
the dirt and Simple Green are outta there.
- compressor air and let it air dry some more
- WD-40 everywhere specially all the joints and moving parts
- compressor air and let it sit for a while so the left over wd-40 evaporates and
your left with new look plastics
I'm a bit of a newbie so if anyone got any comments on this that would be greatly appreciated
I just Hose em down in the laundry tub; Small bucket of hot water and tide with a parts cleaning brush; Blow dry with compressed air; final treatment with a Jig A Loo soaking. A 30 minute job tops when I care. Less than 15 when I don't.
Of course the radio tray and motor is pulled beforehand. And the hingepins pulled and wiped down soon after.
To me, water and RC don't mix, but to each his own. I use Pledge, a toothbrush, and an air compressor at the track. Every other event, I do a complete disassembly, use an ultrasonic cleaner with some greased lightning/simple green on all the components, air hose them off, then reassemble. To lubricate parts, I use a product you can find at bike shops called Epic Ride-it's a dry lube so it doesn't attract dirt as much as a grease. Works like a charm on universals, bearings, hinge pins/a-arms, gears, basically anything that moves or rotates.
Cleaning is really a personal preference, but I still think the guys who hose their cars off are nuts...
If your in a hotel, I recommend this method
