how to hook up amb transponder with spektrum sr3300t
I no this no doubt a stupid question but little confused with this receiver i have a spektrum sr3300t and i am not sure where to plug the amb transponder in at there is now where to plug it in accept on top level with rpm and temp says lap but i thought that was for the control counter? So like i said it sounds stupid to me but just not sure so i fiqured i asked
aux
thought
Thought that's where battery plugged in at
You can power your receiver through any port that isn't a telemetry port. The telemetry ports are 3,3V. So you have 4 ports. Bind, throttle, steering and aux.
What about on a receiver that only has 3 slots. Do I "y" the battery slot?
If thre's only 3 slots, 1 for throttle, 1 for steering, 1 for transponder and if required, a y harness can be used on either the Aux or Batt.
so its safe plug battery into bind slot
So u can use blind port to hook battery to then
Yes you can hook up the battery to the bind port.
you are going to want to hook the battery to the aux, and the transponder to the bind, in case you ever have to rebind your radio in a pinch. That way, you are unplugging the transponder to do it, and not the battery.
