Old 03-07-2011, 05:04 PM   #1
LOSI123's Avatar
Trader Rating: 63 (100%+)
Default Cooked Diff oil?
In my center diff when i pulled it down the oil was 4k weight and it looked greyish black.
is this burned up?
as i dont see how dirt could get in to discolor it.
D8 buggy been running on low traction track with fairly high power motor.
The xray setup book says that its posible to cook centre diff oil if too thin, was wondering if i have done this hence the color.
LOSI123 is offline   Reply With Quote
Old 03-07-2011, 05:07 PM   #2
stallen50's Avatar
Trader Rating: 30 (100%+)
its normal. the discolor is the diff wearing. no problems
agama a8 usa edition
Arrow gtr.21, os speed
savox servos
thanks to my 2013 sponsors: vp-pro tires, hobbypro usa, beta tires, arrow racing, team terribles, boca bearings
stallen50 is offline   Reply With Quote
Old 03-07-2011, 05:08 PM   #3
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
It's time for some fresh diff oil. The coloring is actually metallic particles worn off of the internal diff gears. Double check your internal diff gears, clean and re fill the diff. you should be ok.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 03-07-2011, 05:10 PM   #4
jmaxey51's Avatar
is this burned up?
burnt is more black than grey... but its normal after a few runs... what oil do you use? ive tried almost all oils and i found the mugen oil last far longer than other oils, granted it cost more but over time it will cost you less... i was changing AE oil every 1-2 races and it was greyish and thinning and then i finally broke down and bought mugen oil, ran 4 races, opened up the diff, still clear just like new. wont run another oil anymore... my dad is using up the AE and other oils we had and he has been through a few bottles and i havent even been through half a bottle yet.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 03-07-2011, 05:21 PM   #5
LOSI123's Avatar
Thanks guys, im going to change it, and get some mugen oils.
cheers
Old 03-08-2011, 01:25 AM   #6
Lonestar's Avatar
Mugen oils wear out like all others (I do run them btw)... there's only a handful of factory in the world that do silicon oils, so they all come out of the same cuves
Low traction + low diff weight = diffing out = faster delamination + heat = oil change needed more often
Change oils every half gallon or so
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-08-2011, 06:36 AM   #7
tc5 man's Avatar
i would try ofna diff oil even the lower weight ive used seem to last longer than most before it turned black and it comes in a big bottle
losi diff oil is good also seems constant to me when i used it .
associated diff oil is ok but i did have to change it quicker than most even with 10,000 wt but it is cheap though .
now i do run on a dry dusty track .
Old 03-08-2011, 06:54 AM   #8
Frank L's Avatar
Trader Rating: 148 (100%+)
I have run Losi diff oils for awhile and had them discolor once in awhile but recently I started using kyosho diff oil as the Losi tubes started coming 1/2 size. I think diff oil is diff oil find one that you like and stick with it.
Odonnell Buggy!!! Brad S. Nitro Off-Road 9373 06-03-2016 10:45 AM
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
1:12 Scale at SMA. Decathalon Australian Racing 141 01-16-2013 01:47 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
