Old 03-06-2011, 07:11 PM   #1
Unhappy off road car click
when I push my nitro sidewinder remote control car bakwards it makes a saught of grinding noise and when the car is going it is a bit harder for the engine to move the car it makes a ginding noise. Before the base was bent so we bent it out staight but it still makes the noise.
Bentvanderkroft
Brentvan is offline   Reply With Quote
Old 03-06-2011, 07:14 PM   #2
DiZzYNaTiOn's Avatar
Trader Rating: 25 (100%+)
First thought would be transmision is going out, second would be check the clutch bell and spur gear see if there stripping.
www.filmmakerforum.org
RC8B3 - OS Speed .19 - S9352HV - 4PKS
DiZzYNaTiOn is offline   Reply With Quote
Old 03-06-2011, 07:20 PM   #3
sorry I'm a newbie whats a clutch bell and spur gear
Bentvanderkroft
Old 03-06-2011, 07:22 PM   #4
sorry got to go now
Bentvanderkroft
Old 03-06-2011, 07:30 PM   #5
Hmmm, if its what i think it is you might need to take it to your local hobby shop because i dont know that cars tranny.
The clutch bell is the smaller gear on the engine, that has a bell like shape covering the clutch shoes that grab the bell when the engine is accelerated.
The spur gear is the larger gear that the clutch gear grabs onto and spins it.
So if possible look and the engine and follow it till you see the gear then try and rotate the gear and see if there is any "visual grinding" not the sound but see if there is any teeth missing from the gear etc. If that is good then-
(check the gear box) Grab both back tires and rotate them in opposite directions and see if there is still grinding. Then rotate both tires in the same direction and see if there is grinding, then report back
Old 03-06-2011, 11:40 PM   #6
don't know if this is usefull but the gears on the
engine are quite easy to stop and I know its not the gear box because I took the enginge off and did the thottle maually and it still made the noise
Bentvanderkroft
Old 03-07-2011, 12:57 AM   #7
please help
Bentvanderkroft
Old 03-07-2011, 12:59 AM   #8
I checked the spur gear and I spun the wheels eighther way but didn't show anything
Bentvanderkroft
Old 03-07-2011, 03:41 AM   #9
bgbelden's Avatar
If your saying its not the engine because you removed it then check each diff by stopping the drive shaft from turning and then spin the tires on each end of the car to see if they sound terrible.
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 03-07-2011, 09:21 AM   #10
You need a new clutch set up.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 03-12-2011, 01:03 AM   #11
Smile found problem
the other day when our car crashed into the curb the engine kept going and broke the teeth off the plastic gear so it did not lock into the gear and just rubbed the the plstic gear
Thanks for all your help I apreciate it
Bentvanderkroft
Old 03-12-2011, 01:07 AM   #12
umm sorry how do you close the thread
Bentvanderkroft
SmacTrac...St.Louis Indoor Off Road smac Kansas/Missouri Racing 24520 04-01-2015 03:02 PM
Sioux Falls, South Dakota Off-Road & Oval Racing Facility Northerner Track Locator Forum 9 09-02-2003 10:56 AM
