Old 04-08-2011, 07:53 AM   #76
Integra's Avatar
Stock 427 + Revo + 60mph = [Not possible.
PS RTV copper is Not a Fuel proof silicone. It Will break down over time. If you want a 100% nitro proof sealant your lookin at Three bond 1211 or Racer's Edge Carb sealant. Both will work 1000x better then RTV.
Old 04-08-2011, 08:25 AM   #77
Originally Posted by Redrawker View Post
Yes, there are pry marks on the outside of the case where the PO tried to remove the carb I imagine. They do not reach into the opening where the carb goes though.
I'll grab some copper RTV. Is there anything I can wrap the carb neck with to tighten up the seal as a precaution? I've thought of pipe tape and electrical tape, but I don't know how either would hold up.
I would worry about leaks. I'll look in my parts to see if I have an old carb that will work. I know I have a sirio and rb carb, and I should have a axial case to test fit it. I have a racers edge 32 in my old mgt, I know they are the same carb.
Hot Bodies D8t- Clockwork JL 21/ AB mods C6, JP-1, Spektrum DX3R, JR servos, AKA tires
Hot Bodies D8- RB WS7 III, GRP 2053 pipe, Spektrum DX3R, JR servos, AKA tires
Losi 8t 1.0 mostly upgraded to 2.0 via ebay- RB C5, dynomite 086, spektrum DX3S, orion servos, AKA tires
Muggified LST- Teal head 427, RD logic pipe, JR servos, panther tires
morkendi is offline   Reply With Quote
Old 04-08-2011, 09:34 AM   #78
Alright, I stand corrected. I assumed the radar would be right but hey, it's not that big of a deal haha.
Thank you, I'll order some of the Racers Edge sealant along with my aluminum servo horn.
Alright let me know, I'd be interested in buying a carb second hand if it where in decent shape.
Also, is the carb body the only thing that I need to replace? Amain has replacement bodies for the Axial for $16, which seems like a decent price.
Redrawker is offline   Reply With Quote
Old 04-08-2011, 10:17 AM   #79
nitroexpress's Avatar
Question. From the pics posted, the carb body looks to be metal rather than phenolic/plastic. So I don't see how the pinch bolt could have deformed the carb throat. It might be leaking from scratches or whatever, but I don't see why it won't tighten down. No matter what, it would be a good idea to seal it.
nitroexpress is offline   Reply With Quote
Old 04-08-2011, 07:38 PM   #80
Carb body is metal, and I do not know for a fact that it is leaking, it is simply loose. However, I cannot pull it out when the bolt is snugged, just twist it side to side.
Old 04-18-2011, 05:31 PM   #81
Sealing the carb worked wonders.
However I have yet another small issue. Has anyone else has a problem with the wheel rubbing the end of the turnbuckle at full-lock steering? I adjusted my epa to avoid this, but it takes alot of the travel out of the wheel.
Pictures:
Old 04-18-2011, 05:41 PM   #82
DezSlash's Avatar
Common thing. Mugen angle rod ends As well as RC8T ones. I am running vtr tires and do not have this problem.
Companies I support
Hot Bodies*Futaba*Novarossi*JConcepts*Hitec*Upgrade Rc*Kalgard*Sidewinder Fuel*Dialed
Arcor Raceway
DezSlash is offline   Reply With Quote
Old 04-18-2011, 06:02 PM   #83
I hate to be harsh, but have you ever used the search function? I searched for "wheel rub" and "rim rub" and guess what I found? You got it, a answer to your question.
I know the D8T thread is a bit long, but the search function can be a helpful tool. If everyone started their own "I got questions" thread instead of browsing the original D8T thread, what a mess it would be.
Old 04-18-2011, 07:32 PM   #84
Sorry, I will search from here on out. I normally do, I just felt that this was more than likely my error, and since I had this thread already I thought I'd re-use it.
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
