Got my D8T! Now for questions..
#61
I'll try a heat gun on it and let you know.
With the carb pinch bolt...just because you removed the screw, it doesn't always loosen up the two halves of the retainer. Thread the screw back in about half way, then GENTLY! tap on the screw head. This will seperate the two halves and you should be able to wiggle it out.
#62
I got the carb out finally. I had to remove the collars that the screw holding the carb on thread into. However, I can't get it to snug down no matter what I do... any ideas on that?
#63
My Revo was a Qoncepts BB with a Mach 427 in there. It'd go 65 pretty easily. I think this thing is more in the 30's range with the Axial .28 in there. But thats fine, speed runs aren't were it's at, and the Revo was uncontrollable on a track with my setup lol.
Thanks! I'll give it a shot with a heat gun also.
Yeah that Axial is probably a tad slow. The Mach 427 was an OK engine I suppose. It wasn't much of a powerhouse either, but it moved out plenty. LRP28R Spec 3 was a sick engine in a Revo though ;-) hehehe
#64
Any advise on getting the carb to snug down?
#65
I'm totally at a loss here... waiting on suggestions.
#66
The Mach was all I was comfortable running in the Revo. I had beefed up the drive train, but I didn't want to run the risk of ripping it apart. The Mach was easy to tune, and had a smooth predictable powerband. And it was a heck of a lot stronger than any small block I'd ran So I was happy with it.
#67
#69
Here are some pics like you suggested. I apologize for the poor quality.
EDIT: those turned out worse than I realized. My bad.
To sum it up though, basically the carb throat has two marks on it from the screw, although I cannot tell for certain if they are actual indentions. If they are, they are very faint. When I snug it down, it has movement in the form of twisting, but not up or down travel.
I'm thinking I need a new carb body anyway. This one is marked to pieces.
#70
This is why I never count on used motors unless I have seen it or personally know the person, even if it comes a rtr package. It is nice to be suprised, but I never expect them to be in good shape. I would really think about getting some kind of 21 or such. You can get several for a decent price. Not saying we cant work this out, bepends on if you want to keep dealing with it.
#71
A stock Mach 427 in a Revo is tops a 45 MPH machine...to hit 65 you need something like a modified OS 28.......If you put one of my modified B5's in your truggy it would flat out murder your Revo !!!!!! Axials do not make good truggy engines as they have no top end and really lomit your speed....
#72
I don't really have the $200 to spend on a new engine/exhaust in the first place, so I'm really trying to just get this engine up and running.
#73
I have no doubt a truggy is a better platform than the Revo; and the Axial is far from the best mill that even I have used. However, I'm hoping it'll suffice for some club level racing this spring and summer. If I find I need to upgrade, I'll do it then when money isn't as tight.
#74
may be pic quality, but looks like some damage to the case where the carb goes in? I would defiantly seal it with some high temp copper gasket sealant. A tube is real cheap at the auto part store.
#75
I'll grab some copper RTV. Is there anything I can wrap the carb neck with to tighten up the seal as a precaution? I've thought of pipe tape and electrical tape, but I don't know how either would hold up.
