Old 02-28-2011, 06:37 PM   #1
guss2009's Avatar
Trader Rating: 265 (100%+)
Default Diff oil & grease cleaner help
What can i use to clean all the diff oil/grease of the gear box and gears. I try to brush it off with dish soap and simple green. It didnt work. The brush was full of grease/oil and i had to throw it away because it got worst. Can someone tell me what can i use to clean off the grease and diff oil?
Losi 8ight 3.0 / Losi 8ight 2.0T / CRE Werks B6 Pro / CRE P5XL / Nova 4BTT
/ Dx4r Pro / Hitec 7955tg / Nova/Werks Pipes/ Werks Pro Clutch / Werks Fuel
/ GunHill Road Track (Ft Knox Park) / NYPD
guss2009 is offline   Reply With Quote
Old 02-28-2011, 06:41 PM   #2
Trader Rating: 36 (100%+)
Tea bag your diffs...
Something along the lines of
http://www.bizrate.com/kitchen-suppl...807472733.html
used in a bath of Naptha, which can be found at your local home improvement store in the paint dpt... DIALED!
NitroOB4You is offline   Reply With Quote
Old 02-28-2011, 06:57 PM   #3
omarwashington's Avatar
+1 on Naptha, look in the paint section at home depot. Works great on diff oil/grease.
RCCARS!
omarwashington is offline   Reply With Quote
Old 02-28-2011, 06:58 PM   #4
boomgagem's Avatar
Trader Rating: 45 (100%+)
Send a message via AIM to boomgagem
I'll have to try the Naptha. I've always used denatured alcohol and a stiff toothbrush. Was a little aggravating, but it works
Team Terribles Georgia State Rep
Team Losi Racing
Pineland RC Race Director
boomgagem is offline   Reply With Quote
Old 02-28-2011, 07:07 PM   #5
Nuthin better than a Naptha teabag. Set it in the bath, maybe shake it up a little, let it set for 5 mins, comes out cleaner than new
Old 02-28-2011, 07:11 PM   #6
guss2009's Avatar
Can i get a link of the Naptha? I havent heard of it or seen it. Thanks
Old 02-28-2011, 07:12 PM   #7
mayhem04's Avatar
Give Kalgard De Greaser a try some of the best cleaner your going to find.
www.kalgard.com
Matt
Sponsors: Mugen Seiki Racing -Sweep Racing USA -RadioPost, Powermaster Racing Fuel - Kal-Gard Racing Products - Powered By Mugen's Beat B4 Made by Novarossi NV21B4P
mayhem04 is offline   Reply With Quote
Old 02-28-2011, 07:20 PM   #8
Teccmoney's Avatar
+1 on the kalgard degreaser, I won some in a raffle at Delta RC and I have been using it ever since... Great stuff
Mugen Mbx6t,speed wc II 2060/ Mugen Mbx6, speed powered/ Losi 5ive-T/
SNR Graphite/M2C,BCE,Fioroni,king headz, byrons gen/ M11 spek pro/ Savox HV
*2011 Kyosho Fall Classic Novice Buggy Champ* 2011 CVR Nitro Nights Truggy Champ*
2012 DRC Winter Series Inter. Truggy Champ*
Daryl Wright aka "thefastblackman"
Teccmoney is offline   Reply With Quote
Old 02-28-2011, 07:22 PM   #9
nitroexpress's Avatar
http://www.amazon.com/Rockler-VM-P-N.../dp/B001G9TGQI
nitroexpress is offline   Reply With Quote
Old 02-28-2011, 09:35 PM   #10
Trader Rating: 48 (100%+)
naptha is the only way to go to clean your diffs...
Up in the air...
Cyberacer is offline   Reply With Quote
Old 02-28-2011, 09:42 PM   #11
Naphtha is also known as camp fuel. If you can't find it in the paint section, check the camping stoves section. Kills silicone diff oils very quickly. I usually take the bearings off the diff and drop the diff case in the naphtha, use the teabag thing for the gears and cross pins.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 02-28-2011, 11:08 PM   #12
LOSI123's Avatar
Trader Rating: 63 (100%+)
is it true naptha can swell some diff housings?
LOSI123 is offline   Reply With Quote
Old 02-28-2011, 11:35 PM   #13
AZRC4Me's Avatar
get one of these:
http://www.harborfreight.com/catalog...elry%20cleaner
then fill it with some of this on a 2:1 ratio w/ filtered water:
http://www.greased-lightning.com/op_multipurpose.html
you can get a nice big jug of it at lowe's or home depot for like $7-8, lasts forever. I throw everything in the ultrasonic, bearings, diff cases, gears, etc. Sometimes I mix in some simple green, greased lightning and a little water. Air compressor for the excess, then good as new.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Old 03-01-2011, 10:33 AM   #14
offroad racer's Avatar
One word: DEGREASER. add it to some water and your set
Losi 8ight-T 2.0
Losi 8ight 2.0
TLR 22
Ofna Nitro DM1
offroad racer is offline   Reply With Quote
Old 03-01-2011, 10:42 AM   #15
Do not use it on o rings or other rubber items.
Since some plastics are made different use caution I've used it on my xray diff housing and it came out ok.
RCCARS!
