Old 02-27-2011, 01:15 PM   #1
KyoshoKid's Avatar
Default Losi 2.0 starter box - belt snapping issue
Hi,
I have a 1.0 RTR, it does fit onto the starter box but need to push it forward slightly and towards the starter box flywheel to get a clean fit onto the clutch flywheel. If I donít get it exact then it doesnít turn over but 99% of the time itís OK.
I have snapped 2 belts in the course of 1 month. The first belt broke after 2 weekends of use and same with the second belt.
Has anyone come across this issue? Can I do something to the box to adjust the gears in the starter box? The belt is a hard plastic type, is there another softer belt available (or aftermarket)?
Im thinking the belt is snapping due to when the starter box flywheel is turning but stops suddenly if you move the chassis a bit and doesnít get a clean contact.
Any ideas?
Control the mind, control the finger, control the car
KyoshoKid is offline   Reply With Quote
Old 02-27-2011, 04:23 PM   #2
abqNitro's Avatar
Well at least I know im not the only one who is having this problem!
abqNitro is offline   Reply With Quote
Old 02-27-2011, 06:11 PM   #3
dash riprock's Avatar
I dont know if this will help but I have a 2.0 version Losi starter box.The belt in it broke just after I bought it.I replaced it with this: http://cgi.ebay.ca/LOSI-8B-T-2-0-Sta...item3f050f0dd3 This belt is 100 times better than the original.Just make sure what box you have before hand if you plan on getting one of these belts.All I did when I found this belt was look up the Losi part number for it then search ebay for that number.Hope this helps.
Tony Hopcraft
Losi 8ight-T 2.0 Losi 8ight 2.0 Losi Mini-Late Model,Losi L8ight Model
Hobby Revolution Team Driver
dash riprock is offline   Reply With Quote
Old 02-27-2011, 07:47 PM   #4
KyoshoKid's Avatar
Thanks for that. Ive ordered a few off ebay, hopefully they last!!
Old 02-27-2011, 07:54 PM   #5
tc5 man's Avatar
when you get them dont set the belts on it to tight or to loose about 1mm to 2mm is good .
tc5 man is online now   Reply With Quote
Old 02-27-2011, 08:17 PM   #6
KyoshoKid's Avatar
How do I adjust the belt tension?
Old 02-27-2011, 08:42 PM   #7
tc5 man's Avatar
the, bolts that are into the motor holes just slide the motor back to "tighten the belt" and move foward to lossen than hold the motor in place and tighten the screws .
i, dont have the "2.0 starter box" i have the black losi eight stater box but i think the only thing diffrent about the 2.0 eight starter box is its red and has 775 motors.
you adjust it just like gear meshing on your buggy/truggy.
Old 02-27-2011, 08:53 PM   #8
KyoshoKid's Avatar
Thanks, I'll have a look at the motor screws and see how I go.
Old 02-27-2011, 08:54 PM   #9
tc5 man's Avatar
no problem just remember to have 1mm to 2mm of play in the belt or it will snap.
1mm is what i whould try first.
Old 02-27-2011, 09:46 PM   #10
808gx7r's Avatar
Hi,
Any ideas?
if it a direct drive(belt on the pinion) i wouldnt know.
but my goes from pinion to a shaft then anther belt(same sort of box) to anther shaft that holds the wheel. and i snapped a few in one weekend. it was the meshing of the gears... was straining it
Mugen Mbx6t / O.S SPEED / Byrons / Savox servos / Futaba
Agama A8 Evo / O.S SPEED / savox / futaba
Hpi Blitz/sc10 CASTLE CREATIONS.
Driving the best quality cars in the market.
808gx7r is offline   Reply With Quote
Old 02-28-2011, 06:50 PM   #11
crotty777's Avatar
one of the problems i have found with these boxes is if the lid gets pushed down to far at one time or another the contact will get bent a little to much. This is causing the starter wheel and flywheel comming together before the starter box motor starts turning. To fix, open the box and bend the contact up a little bit so that the motors come on a little sooner, this will cause the starter box motor to start spinning and get up to speed before your flywheel touches. Hope this helps, it kinda hard to try and explain without showing.
*Dialed RC Hobbies, Windwater RC, Kustom Kolors, HRP, Sweep Racing,
RC Concept*
crotty777 is offline   Reply With Quote
Old 02-28-2011, 07:39 PM   #12
KyoshoKid's Avatar
Im assuming you're talking about the metal bit under the springs that get pushed down, part# LOSA99428? http://www.losi.com/ProdInfo/Files/LOSA99059Manual.pdf
Old 02-28-2011, 07:41 PM   #13
KyoshoKid's Avatar
Thanks for all your feedback, I havent had a chance to look at the starter box, hopefully in the next day or so. I'll report back with my findings.
Old 02-28-2011, 08:51 PM   #14
CHOAS's Avatar
I broke three stock belts in a week,well everone using my box to break in there engines because theirs were dead but anyway I bought one of these but have not tried it yet because I have not broke another belt in months.
Go figure. Oh yea when I went to get the third belt no one had them and everyone said backordered so I had to buy a new box.
TEAM KHAOS II- TLR 8T 3.0 / NOVAROSSI "ROMA" / VP FUEL / HITEC
TEAM KHAOS II- TLR 8B 4.0 / JQ "THE ENGINE" / VP FUEL / HITEC
FYI - team member opportunities open/ be advised we only accept applications from drivers over age 47, w/ decreased vision, slowed reflexes & reaction time, debilitating physical injuries acquired from over work, old age or prior lapse in judgment of capabilities!
CHOAS is offline   Reply With Quote
Old 02-28-2011, 09:06 PM   #15
crotty777's Avatar
Yes
RC Concept*
