Old 02-26-2011, 06:34 PM   #1
Default OS Max engine question
my rear seal is leaking behind the flywheel dumping fuel out and making a mess, I have the head off, carb, front engine cover, my question is how in the heck do you get the connecting rod off the crank to be able to get the rod and piston out of the cyl to be able to get the crank out of the block??
replacement seal from a-main or lhs??
thanks
jeff14346 is offline   Reply With Quote
Old 02-26-2011, 06:49 PM   #2
jrock32's Avatar
Send a message via MSN to jrock32
You need to pull the sleeve out. Once you do that, you can remove the rod from the crank and pull it out with the piston. Sometimes it's difficult to pull the sleeve out. I keep the flywheel on the crank and put the piston at bottom dead center. Insert a zip tie through the exhaust port which would stick out of the tope of the sleeve. Turn the flywheel so the piston pushes on the zip tie in return lifts the sleeve out of the case. Sometimes the zip ties will break.
Hope that helps.
Jordan Wilson
Jordan Wilson
O'Donnell Racing Fuel ☆ Hobbico ☆ Futaba/O.S. ☆ TrakPower ☆ Fastlane Graphix ☆ Kal-Gard ☆ Paint by Kiefer Designs ☆ Thank you for the awesome products and support!
jrock32 is offline   Reply With Quote
Old 02-26-2011, 07:02 PM   #3
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
thanks
how much fuel on your motor? and what kind temps is it running? i mean if it to fat it going to leak the fuel got go some where
also you got take the sleave out first then use a peice of dental flos and pull the rod pop off
is the bearing is bad you got replace not the seal i bet not lean enought
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 02-27-2011, 07:15 AM   #4
NDHotbodies's Avatar
pre heat the head just like you would do on start up, and the sleeve will come out easier..
self sponsored, flat broke, highly sought after test dummy for Hotbodies..
I don't spell wrong, I just use shorthand sum time..
NDHotbodies is offline   Reply With Quote
Old 02-28-2011, 07:25 PM   #5
thanks for all the tips, motor totaly disassemled
yes it was probably on the rich side, still learning how to tune nitro
OS MAX 21XZ-R ~~FULL PHOTO~~ FF25510 Offroad Nitro Engine Forum 178 03-22-2013 02:35 PM
Buggy engine: OS MAX-21 RG-X or STS D21B? drakuli Nitro Off-Road 8 10-03-2009 03:32 PM
