Old 02-26-2011, 01:41 PM   #1
morocho1979's Avatar
Default popout driveshaft HB D8T
Hello i have a trouble with my truggy hotbodies the rear driveshaft popout i change driveshaft ,rear arm,rear hub ,upperlinks,outdrive and still popout what can i do ???
Juan (morocho) MBX6R-us
Caracas,Venezuela
www.venezuela-rc.com
http://www.cocinasdada.com
http://www.race-monitor.com
morocho1979 is offline   Reply With Quote
Old 02-27-2011, 07:19 AM   #2
NDHotbodies's Avatar
go to the D8t thread, this has been brought up a couple times and those guys well help you out.. all 3 of my D8ts do this also..
self sponsored, flat broke, highly sought after test dummy for Hotbodies..
I don't spell wrong, I just use shorthand sum time..
NDHotbodies is offline   Reply With Quote
Old 02-27-2011, 07:26 AM   #3
rceefreak's Avatar
Trader Rating: 139 (100%+)
Not sayin this what is goin on here, but do u have the rear hubs on the correct sides. I know with some if u have the right hub on the left side and vice versa it makes the width wider and dogbones don't sit as far in the outdrive as they should be. Just a thought
rceefreak is offline   Reply With Quote
Old 02-27-2011, 11:22 AM   #4
Trader Rating: 47 (100%+)
Try running less drop on the rear arms.
rageworks is offline   Reply With Quote
Old 02-27-2011, 12:35 PM   #5
my droop is currently set at pretty much straight across even with the chassis.. can not let it go any lower than that as the axle will pop out.
Old 02-27-2011, 05:33 PM   #6
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
measure your axles, make shure chassis wasnt drilled wrong. droop should nut be a issue you can run 116 and the shouldnt pop out. something is either bent, flexing or just wrong.
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 02-27-2011, 06:54 PM   #7
I just came from checking one of my trucks and on the right rear with no droop setting, the axle would probably pop out.. the left side is in a little farther.. I'll check the other two trucks the next couple nights..the one I checked probably has two races on it and no hard hits or wrecks were done on this one..everything else looked good and straight, bearings are good..as are the drive cups..
