Old 02-25-2011, 10:06 PM   #1
Default Off Road Buggy with On-Road tires?
Hello guys i am new to this forum but have average experience with RC and nitro engines (i'm a mechanic)
My question is, has anybody put On road tyres on an off road vehicle in an attempt to improve road handling?
I own a cheap and cheerful HSP 10th buggy and love its speed however the handling could do with a bit of tweaking. would it be beneficial to use some tyres from say the 10th HSP nitro on road cars (not drift cars).
also what is a good base setting for my toe-in/out and camber alignment for front and rear wheels?
thanks
HSP-Nutjob is offline   Reply With Quote
Old 02-25-2011, 10:40 PM   #2
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
If its somthing you want to try then do so. Make sure when you buy the hex are right size. Also try since ur on road lowering suspension for low cg.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 02-25-2011, 10:42 PM   #3
AZRC4Me's Avatar
If you're running an off-road car on pavement, you can definitely try some on-road rubber tires like slicks or something with an on-road tread, or even foam tires. Not sure what will fit the car.
As for toe, start with about 1-1.5 deg of toe out in the front, 2-3 deg toe in in the rear (front wheels angling out, rear wheels angling in) and go from there. You could also probably run some stiffer springs and heavier shock oil to improve on-road handling.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Old 02-25-2011, 10:59 PM   #4
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
I have a set of road tires for my 1/8 Buggy for when I test n tune at home ;-)
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Twister Adherence Off-Road Buggy Tires GMartinez Nitro Off-Road 21 12-18-2008 05:36 PM
