Old 02-21-2011, 09:22 PM   #1
Default wat does it mean?..
What do they mean when they say "your engine not clearing out on the straights"??
mk74 is offline   Reply With Quote
Old 02-21-2011, 09:27 PM   #2
trickedout's Avatar
Trader Rating: 31 (100%+)
It means your High Speed Needle is set to rich causing the motor to not burn all the fuel the carb is dumping into the motor...Lean your high speed an hour at a time until it doesnt sound like its blubbering down the straight a way...
In the middle of some changes
*702 RC Raceway* *WindWater Raceway*
trickedout is offline   Reply With Quote
Old 02-21-2011, 09:27 PM   #3
cjwilly's Avatar
It means your high speed needle is set too rich. The engine cannot reach max rpm, it will smoke a lot and have poor performance.
cjwilly is offline   Reply With Quote
Old 02-21-2011, 09:31 PM   #4
aussies1129's Avatar
Trader Rating: 74 (100%+)
this is a tune issue, if your engine is not tuned correctly most likley your high set needle therefore its not up to temperature then you will have excess fuel in your engine the characteristics is your engine will cough and carry on running terrible therefore the term not clearing out down the straight is used, get your tune sorted out with your HSN and this will not be an issue.
goodluck
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 02-21-2011, 09:41 PM   #5
Thanks guys.. I read this in one of the tuning posts. The next thing the guy said is to lean out your HSN until your car is just barely clearing out the straightaway.
So I guess it means right at the end of the starightaway your car would hit its max rpm??
Old 02-21-2011, 10:09 PM   #6
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
Its too fat. Meaning engine is not reaching top speed because tune is off. Just lean top end hour at a time to where u get a nice thin line of smoke.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 03:10 AM
Piks of your MEAN mini!! ProudSavageOwnr Micro and Mini Scales 53 09-07-2006 07:52 PM
