Old 02-22-2011, 04:26 PM   #31
bre1979's Avatar
I have to do this to my box.
Team Associated, Venom, Tekin, Ofna, DE RACING, J CONCEPTS, Savox, AKA, PROLINE,
bre1979 is offline   Reply With Quote
Old 02-22-2011, 06:40 PM   #32
Integra's Avatar
Originally Posted by teeforb View Post
how is it using 5S compared to 4S?
seeing as our motor's in our boxes are rated up to 18volts, I would guess your box will be a bit more powerful and might have a slightly shorter life span for the fact a 5S is a Hair over 18volts. But like anything electrical If you take care of it and Dont try and Force start a motor that's Locked at TDC or Bottoming out on the chassis you should be good to go for years to come.
Old 02-23-2011, 06:09 AM   #33
i would think it's max by amps and voltage. Like a 12v 30AMP relay or a 1v .5Amp relay. I believe a relay is just some bjt, Darlington pairs, or some kink of high amp transistors. Therefore, specs are important.
and there's SPDT (single pole double throw) and SPST (single pole single throw)...
I'm using a 12V/40A SPST, you could use a SPST or SPDT as long as you use the normally open contact
A relay is a simple electromechanical device, there is no bjt, Darlington pairs, or some kink of high amp transistors in there.
To save the "life" of the relay contact I use a capacitor of 40V/3000uF in parallel to the coil, this way you avoid the short-cycles that would eventually kill the contact .
BiteTheBullet is offline   Reply With Quote
Old 02-23-2011, 06:23 AM   #34
Wiring diagram anyone?
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 02-23-2011, 07:38 AM   #35
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Can u elaborate on short cycle?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 02-23-2011, 08:05 AM   #36
teeforb's Avatar
here is a good page...
http://www.mp3car.com/the-faq-empori...ire-it-up.html
Old 02-23-2011, 09:12 AM   #37
teeforb's Avatar
Got a 30amp relay. Is that big enough?
Old 02-23-2011, 09:30 AM   #38
trickedout's Avatar
Trader Rating: 31 (100%+)
Great little read there for those unfamiliar with relays. Yes a 12v 30a relay should be just fine
In the middle of some changes
*702 RC Raceway* *WindWater Raceway*
trickedout is offline   Reply With Quote
Old 02-23-2011, 10:02 AM   #39
teeforb's Avatar
in regards of hooking it up...
pin 85 --------> lipo gnd
lipo pos --------> starter box switch ____/ ____ ---------> pin 86
lipo pos ---------> pin 30
pin 87 ----------> + on Motor
lipo gnd -----------> gnd of motor
is this correct?
Old 02-23-2011, 11:06 AM   #40
trickedout's Avatar
is this correct?
Yes i believe that looks correct, if you plan to keep your Switch, if not pin 86 will hook up straight to the contact spring when you push the car down...Having the switch just breaks that connection when not on.
Old 02-23-2011, 01:43 PM   #41
is this correct?
I'm going to post here the link for the circuit and a photo of my installation, post them here if you wish:
h ttp://img64.imageshack.us/img64/7646/circuitocaixaus.jpg
h ttp://img27.imageshack.us/img27/8859/caixa1.jpg
About short-cycle, if you press the car in the box and for an instant you let the switch go off and them press the car again, your are wearing the relay contact, if you look at the graph you will see that the switch was let of in the instants t1, t2 and t3, but the motor keeps spinning avoiding the relay to open and close for 3 times. Is it clear?
Old 02-23-2011, 02:29 PM   #42
teeforb's Avatar
so you prevent on/off cycles when pressing down on the box, by storing charge in the cap. once u let off the box for T=t, the cap discharges and the relay opens.
Old 02-23-2011, 09:08 PM   #43
teeforb's Avatar
I hooked up the relay with the cap. I only found a 4700 micro F. I think that was go big. It's a 1.5sec delay in the spin. Hope it won't be a big deal for starting. This mod is a good idea! Esp the cap part. Thanks all for the info. Sharing is caring, is what my 3 year old daughter always tell me!
Old 02-23-2011, 11:39 PM   #44
Can someone point out how do you wire the relay and the capacitor with a wiring diagram like this? Thanks in advance!
Just noticed these two wiring diagram are a bit different, any pointers?
Old 02-24-2011, 06:01 AM   #45
Gary NJ's Avatar
Sorry, didn't get back to this thread after I posted earlier. Integra covered it all. The motor certainly spins harder on 5S....
I was thinking about doing a GMK Supply 12V relay upgrade kit for boxes for a year now...this thread may finally get me off my ass to do it!
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Best Lipo for Ofna Blue Truggy Starter Box? Armaan Nitro Off-Road 114 10-03-2010 07:25 AM
Ofna Blue starter box, tools, reciever, Hitec 7955, 1/8th tires, etc etc FS/FT Dlewis4 R/C Items: For Sale/Trade 10 08-21-2010 03:32 AM
Ofna truggy starter box - rewire for Lipo? dsl Nitro Off-Road 17 08-25-2009 11:37 AM
