Old 02-21-2011, 06:15 PM   #16
boomgagem's Avatar
Trader Rating: 45 (100%+)
Send a message via AIM to boomgagem
Yeah I did what McFly did and works great. Doesn't spark nearly as bad.
Yeah my poor box has been the community box before. Along with my ingitor, and fuel bottle (by accident)
Team Terribles Georgia State Rep
Team Losi Racing
Pineland RC Race Director
boomgagem is offline   Reply With Quote
Old 02-21-2011, 06:19 PM   #17
This is what I found:
It is grounded and note the fuse/breaker...
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 02-21-2011, 07:04 PM   #18
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
I'm not clear how the relay helps... Can you elaborate?
Originally Posted by McFly505 View Post
Re-post...
To all those with the same setup, you WILL eventually have the same problem.
Theses starter boxes have little, flimsy contacts that, in stock form, handle ALL of the current the motors pull. Not quite the hot setup, IMO.
I had the same issue, so I made new contacts from copper(1/2" copper tube, smashed flat and cut/dremel'd to fit), but I still wasn't happy with the performance I was getting.
So I took it one step further and added a relay to handle the current.
This setup may be overkill, but it ALWAYS works and it's one less thing to worry about come race day.
And yes, it WILL start a Mack truck....
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 02-21-2011, 07:54 PM   #19
Instead of all current running through the switch and/or contacts, the relay handles it.
Without the relay, the contacts end up getting smoked and your left with a box that won't work when you need it the most.
It is certainly not necessary, but it will definitely make life easier on the box.
McFly505 is offline   Reply With Quote
Old 02-21-2011, 08:02 PM   #20
teeforb's Avatar
I see. So pushing down the starter box just turns on the switch instead of passing the current to the motors. What part are u using?
Old 02-21-2011, 08:11 PM   #21
Any wiring diagram? Thanks!
Old 02-22-2011, 10:27 AM   #22
I'll get you guys a wiring diagram when I get back home.
I'm out truckin!!!
Old 02-22-2011, 10:34 AM   #23
teeforb's Avatar
I'm out truckin!!!
Part to!
Old 02-22-2011, 11:50 AM   #24
I did the same thing to my OFNA chrome top the first day that I bought, it's still working in 2 years of use.
I have a diagram made in Eplan, but I cannot post images since I'm new to the forum.
BiteTheBullet is offline   Reply With Quote
Old 02-22-2011, 11:57 AM   #25
teeforb's Avatar
What's the exact part number u used?
Old 02-22-2011, 12:03 PM   #26
Gary NJ's Avatar
Originally Posted by teeforb View Post
I have a 5s 4200mah 35c I can turn into a 4s. Shall I do that?
I've been runny my Ofna truggy box on 5S for a year now and it works great. So does using a 12v relay - much better than the brass contacts. Solder the leads to the motor, ditch the on/off switch, and use decent wire and battery connectors and you're golden.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 02-22-2011, 12:53 PM   #27
teeforb's Avatar
What's the part number?
Old 02-22-2011, 02:44 PM   #28
There is no part number teeforb, it's a simple car relay, you should find it really easy in a auto shop
Old 02-22-2011, 03:29 PM   #29
teeforb's Avatar
i would think it's max by amps and voltage. Like a 12v 30AMP relay or a 1v .5Amp relay. I believe a relay is just some bjt, Darlington pairs, or some kink of high amp transistors. Therefore, specs are important.
and there's SPDT (single pole double throw) and SPST (single pole single throw)...
Old 02-22-2011, 03:31 PM   #30
teeforb's Avatar
how is it using 5S compared to 4S?
Best Lipo for Ofna Blue Truggy Starter Box? Armaan Nitro Off-Road 114 10-03-2010 07:25 AM
Ofna Blue starter box, tools, reciever, Hitec 7955, 1/8th tires, etc etc FS/FT Dlewis4 R/C Items: For Sale/Trade 10 08-21-2010 03:32 AM
Ofna truggy starter box - rewire for Lipo? dsl Nitro Off-Road 17 08-25-2009 11:37 AM
