Like Tree1Likes
Old 02-22-2011, 07:31 AM   #16
wingracer's Avatar
Trader Rating: 23 (100%+)
Originally Posted by BigAlz View Post
Would be nice to find a cheat sheet of what comes in the kits
Go with the Boca method. Figure out what you need for whatever cars you have and make kits for them, then make an offer. Anyone that wants a kit for a different car just needs to send you a list of every screw and in exchange you will give them 10% off on the order or something like that. Then you have another car to add to your offerings.
I've been thinking of doing the same thing myself.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-22-2011, 07:49 AM   #17
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
That's a good idea. Id imagine a large % share very similar sizes. That would help prices when getting some quotes
Alan Hall
AlanHall is offline   Reply With Quote
Old 02-22-2011, 08:39 AM   #18
Integra's Avatar
There's alot of different sizes when you think about it. When you figure in some cars run Standard US hardware and some use Metric. Still a good Idea BigAlz, Keep up posted on what you come up with.
Old 02-22-2011, 08:57 AM   #19
utah300rum's Avatar
Trader Rating: 27 (100%+)
I have used RC Screwz with good and bad results.....I have noticed in the same package..same size..apparently different brands or grades of screws.
I have a set for my Summit and have noticed some are much softer than others, in the exact same size screw...and looking closely have seen different markings on the screws.
I wish it was more consistant with the "harder" screws....they do seem to be softer and prone to strip if your drivers are worn or you are using ball ended drivers.....but for the Summit I preffer the stainless screws since it plays in the snow often.
My "racing" vehicles that dont get wet, I preffer the better quality standard screws, my "bashing" trucks get stainless, and I am just more careful when working on them.
I have purchased a few screw sets from ebay they are the same quality as I get from the local hardware store....I will have to get a set from Tony's and see if they are a better grade.
Spooky's Racing for Asphalt & Carpet, Blacksheep Raceway for off-road, Utah Mountains for bashing!
utah300rum is offline   Reply With Quote
Old 02-22-2011, 09:22 AM   #20
AlanHall's Avatar
I could do the stainless like Rc screws no problem. But I was thinking something a little morre catering to racers .. strong and light. This thread has the gears turning again. Integra- as fir size I meant car brand to car brand. I figured there would be some similar
Alan Hall
Old 02-22-2011, 11:07 AM   #21
KyLayfield's Avatar
Trader Rating: 86 (99%+)
Check out Hexcrews.com, they make grade 12.9 screws with a zinc-nickel coating that's corrosive resistant. I haven't found a better option than these in terms of strength, cost and appearance. They also eliminate the button heads with cap heads which allows you to use a larger wrench size. If you car isn't on the screw kit list it can be created in a few days. Just make sure you have a quality set of wrenches because soft tips won't last long with these.
http://www.hexcrews.com/hexheads-screw-kits.aspx
http://www.hexcrews.com/hexheadsap-factsheet.htm
KyLayfield is offline   Reply With Quote
Old 02-22-2011, 12:03 PM   #22
AlanHall's Avatar
30% stronger than titanium?
Alan Hall
Old 02-22-2011, 12:20 PM   #23
Ambros303's Avatar
A titanium screw is weaker the a hardened steel one (same size screw). The titanium one is much lighter tho and that is why it is interesting to use them if you want to save weight.
Kyosho ST-RR Evo-ed // Sirio // Hitec // Sanwa
Kyosho MP9 TKI2 WC // Sirio // Savox // Sanwa
Ambros303 is offline   Reply With Quote
Old 02-22-2011, 12:33 PM   #24
KyLayfield's Avatar
Titanium isn't really regarded for strength, but more for it's strength-to-weight ratio. In general, by volume, steel has it beat. There are always exceptions with grades but anywhere there will be a lot of stress such as diff cases, shock mounting or camber links, I would be careful to put a Ti screw. If you do some research on the internet you'll see that titanium gets a lot more credit than what it's worth.
Old 02-22-2011, 12:45 PM   #25
wingracer's Avatar
Pretty much what these guys said:
Originally Posted by KyLayfield View Post
Titanium isn't really regarded for strength, but more for it's strength-to-weight ratio. In general, by volume, steel has it beat. There are always exceptions with grades but anywhere there will there will be a lot of stress such as diff cases, shock mounting or camber links, I would be careful to put a Ti screw. If you do some research on the internet you'll see that titanium gets a lot more credit than what it's worth.
Basically, Ti has a higher strength to weight ratio than all but the best high strength steel. But by volume, steel is stronger except for low grade steels.
To put it another way, lets say you are designing an aircraft. You determine that a bolt needs to be at least as strong as a 10mm high strength steel bolt. These are your options:
1. Use a 10mm steel bolt.
2. A 10mm Ti bolt will not be strong enough.
3. An 11mm Ti bolt will give you the same strength and be slightly lighter.
4. A 12mm Ti bolt will be the same weight and be slightly stronger.
Numbers used as an example, not real facts.
But if space does not allow the use of a larger bolt, then the 10mm steel bolt is your only option.
Team Shepherd USA
Old 02-22-2011, 12:51 PM   #26
AlanHall's Avatar
i see
Alan Hall
Old 02-22-2011, 01:09 PM   #27
Ambros303's Avatar
I think i've posted this one before on a different thread but it really says it all:
Old 02-22-2011, 01:24 PM   #28
AlanHall's Avatar
So a titanium "screw kit" wouldn't make alot of sence. Cause there's only a few spots to use it. But I can still also think of alot of places it would be good. Just wonder if it would be worth the investment
Alan Hall
Old 02-22-2011, 05:05 PM   #29
drewmugx5t's Avatar
Trader Rating: 21 (96%+)
VSR is a local guy in NC who does screw kits. Really nice stuff.
TeamXtremerc.com
MBX6-XZ-B Speed, MBX6T-Ninja, Hitec, Savox, Futaba 4pk
drewmugx5t is offline   Reply With Quote
Old 02-22-2011, 05:37 PM   #30
Originally Posted by boomgagem View Post
I get my screw kits and bearings from a local guy here. Awesome screws and a great guy...
http://www.4chobbysupply.com/servlet...its/Categories
+1
kings & reds
grouseridge is offline   Reply With Quote
Brand New 1/16 Merv Body and Stainless Steel RC Screws Set. Bmr4life R/C Items: For Sale/Trade 9 01-11-2011 09:17 AM
ARGE TAK MASUK AKAL..QUIT RC zargos89 Malaysian Forsale-Trade 10 04-23-2010 09:34 AM
John's out RC sale - Mi3/DX3r/HaulerBag/Tools/Chargers/Lipos/Slash/Crawler + cheap!!! guerd87 Australia For Sale/Trade 14 09-19-2009 06:28 AM
Huge Losi/Associated parts sell out. If you own a RC car get your parts here. DustinR R/C Items: For Sale/Trade 21 08-08-2006 07:11 PM
