Old 02-17-2011, 05:03 AM   #1
koopesv's Avatar
Trader Rating: 18 (95%+)
Default What bearing?
I wanted to know what bearings you guys are using? Rubber, metal sheilded, or ceramic and what brand.
For your buggies and truggies by the way.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 02-17-2011, 05:08 AM   #2
davet323's Avatar
Avid bearings are good never had any problems with them
davet323 is offline   Reply With Quote
Old 02-17-2011, 06:14 AM   #3
mayhem04's Avatar
Hands down AVID Bearings I use the Revolution bearings great price , great quality and even better customer support.
Matt
Sponsors: Mugen Seiki Racing -Sweep Racing USA -RadioPost, Powermaster Racing Fuel - Kal-Gard Racing Products - Powered By Mugen's Beat B4 Made by Novarossi NV21B4P
mayhem04 is offline   Reply With Quote
Old 02-17-2011, 06:58 AM   #4
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Answer, Avid, Boca, Acer, Protek, TKO,
Pretty much used some from just about all those and then some. Right now it's Answer and Avids mostly.
Rubber seals in some places (usually with one seal removed on stock kit bearings), Revolutions (or simular style with one metal sheild and rubber or teflon sheild), Ceramic's if the track surface isn't too dirty or if I want a more free drive train. Pretty much depends on what I want/need the bearing for in a given location.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 02-17-2011, 07:05 AM   #5
jpz_67's Avatar
Trader Rating: 56 (100%+)
I use Abec35's rubber sealed. I prefer the longevity out of rubber sealed bearings vs metal shielded. Very good product and have been using them for several years.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 02-17-2011, 07:13 AM   #6
tc5 man's Avatar
rubber sheid on my 1/8 truggy and 1/8 buggy i use protek and tko bearings and avid .
tko for the clutch bearings and protek or avid bearings for the drivetrain.
i leave the shields and grease in the bearings on the drivetrain so they will last .
Old 02-17-2011, 08:06 AM   #7
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Acer Ceramic (rubber shield) all around the car.
Nothing but Kyosho steel (steel shield) in the clutch!
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 02-17-2011, 08:44 AM   #8
vwduud's Avatar
Trader Rating: 45 (100%+)
I am still operating under the notion that 1/8 scale offroad racing "eats" bearings (at least wheel bearings).
As a result, I keep a supply of $1.00 bearings (usually Avid Revolutions - rubber shield one side, metal shield on the other) on hand.
Weekly PM is to inspect and replace ANY bearing that feels questionable (NOT smooth).
I got curious one day to try and determine whether or not a "gritty feeling" bearing was due to dirt infiltration or bearing damage (balls, races, etc.).
I removed both shields to be able to thoroughly clean the bearing. After numerous sprays with chemical degreasers and compressed air, I felt fairly convinced that all grease and any other foreign material was gone.
The bearing still felt "gritty" or just not smooth; no different from when the seals were still on.
I stopped there and just assumed ball or race damage due to the high impact the wheel bearings go through during a race on these MX still tracks we have today. On another note, the diff bearings (both outdrive and pinion) last noticeably longer, even though they attract the same, if not more dirt around the bearing seals. Seeing as they do not take the impact that wheel bearings do, I suppose this makes sense. The test I performed above was on a wheel bearing.
So my conclusion is to still keep $1.00 bearings on hand, viewing wheel bearings as disposable items.
I have wanted to try a more expensive wheel bearing just to see if they last any longer. My only experience with ceramic has been replacing the diff balls in my 1/12th scale with ceramic. In that test, I didn't notice any longer life than standard, so I have refrained from trying this in 1/8th scale.
Has anyone done this type of test to determine if you get at least 5 times the life (average) out of a $5.00 ceramic wheel bearing as compared to a $1.00 bearing? Until it's definitive that I can get at least 5 times the life (hopefully more) out of a more expensive bearing, I will stay with the $1.00 bearings. Which in most cases, I get more than 2 club level events on these bearings. Longer on tracks with less MX style jumps (less crashing, harder landings, etc.).
Your thoughts?
Jim Brown
Tekno EB-48.4, ET-48, Rx8 G2, 1900kv/2000kv, Savox 2274/2273, SMC, 4PX
Sponsors: Tekno, RC Crew Chief (chassis tuning S/W)
President of SCR (just outside New Orleans) - https://www.facebook.com/scr.raceway
vwduud is offline   Reply With Quote
Old 02-17-2011, 08:57 AM   #9
johnnyboy's Avatar
I still find you get what you pay for (to some extent). Last season I ran my MP9SE box stock (stock bearings) for an entire season and I only had to replace one outer rear hub bearing. The rest were still very smooth. I attribute this to them being NSK bearings (high quality Japanese bearing company). The $1 bearings just do not last as long in my opinion (yes I have tried a few different types over the years). I just wanted to try the ceramic Acer bearings this year to see if they were worth it (for durability and weight savings). I find their seals to be very good with little friction. We will see how they hold up. I would much rather just have a decent set in there to begin with and not have to change bearings all the time (with 18 or so bearings, my time is worth more...lol).
Also, never bother cleaning a gritty bearing. If it is gritty, the races have been pitted and the bearing is done.
Old 02-17-2011, 08:57 AM   #10
mp9er's Avatar
Post
BOCA
TEAM BOB AND JIMBO RACING,
mp9er is offline   Reply With Quote
Old 02-17-2011, 09:58 AM   #11
koopesv's Avatar
Good info fellas Im gonna try Avid Ceramics for my wheels hubs and revolutions on the drivetrain and see how that works out.
Urban Heat Racing
Old 02-17-2011, 11:35 AM   #12
Frank L's Avatar
Trader Rating: 148 (100%+)
The avid revolution bearings work well but I find that the tko $1 bearings seem to last a little longer. And in the clutch I only use tko special clutch bearings. Just drop them in and forget about them until the shoes need to be changed.
Old 02-17-2011, 01:43 PM   #13
Boca Bearings, yellow seal Best in the Business.
Im the wrench man
Boca Bearings~Pro-Line Racing~Radiopost~VP Pro USA
RcRacer37E is offline   Reply With Quote
Old 02-17-2011, 01:46 PM   #14
They all are good. I have used them ALL. I can not honestly say which is best.
But I will say this, I will not spend more that a buck on a bearing - period. dont care if it took the monkey to the moon. I prefer yellow sealed Avid.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 02-17-2011, 01:58 PM   #15
koopesv's Avatar
For those who clean there bearings what kind of grease are you using?
Urban Heat Racing
Novak Ballistic motor bearing questions CoolestDinosoar Electric Off-Road 16 06-27-2010 09:47 AM
What buggy? HB D8 or Losi 8v2? Xchange Nitro Off-Road 67 02-13-2009 01:36 PM
Bearing Cleaning/Re-Lube almtx3 Nitro On-Road 25 09-02-2008 11:07 AM
What bearing oil do you recommend FUK_WRX Electric On-Road 28 06-16-2004 05:42 AM
