Old 02-17-2011, 10:35 AM   #31
FOXC's Avatar
Originally Posted by tnacvols View Post
How would I know if the lipo is discharged below a safe level or the battery is at 60-70%?
To start out, the alarm would be the safest way to prevent going below that 3.6v mark.
Get yourself a decent lipo charger that has a built in balancer. I can highly recommend Hyperion chargers. I picked mine up from amain.
With a good charger/balancer you will be able to maintain the lipos for a long life. The balance function will show you the voltage of each cell and also youll be able to set a charge capacity setting of 60-70% for storage if you not going to use the lipos for a week or more.
I run 4s 5000mah in my starter boxes with no voltage alarm, but I dont run the lipos down in capacity very far. I can run all day using the starter boxes and not even use half the capacity in the lipos. At the end of the day I just throw them on the charger and check them to make sure.
If you know your not going to run again for a week or more than simply hook'em up to the charger and charge to 60% or discharge down to 60%...whichever way.
But definately invest in a decent lipo and charger/balancer. Might run a few bucks more up front...but it will be money saved down the road.
TLR 2.0EU/Novarossi+4/MLC Fuel/AKA/Fastlane Graphix
TLR 2.0T/Werks B5/MLC Fuel/AKA/Fastlane Graphix
www.rhein-main-circuit.de
FOXC is offline   Reply With Quote
Old 02-17-2011, 11:48 AM   #32
Trader Rating: 50 (100%+)
Ooooooh ok I see now. Thanks for the input
tnacvols is offline   Reply With Quote
Lipo battery for losi starter box guss2009 Radio and Electronics 21 05-25-2010 08:14 PM
Lipo battery for losi starter box help guss2009 Radio and Electronics 11 04-15-2010 07:26 AM
???????need help wiring a starter box????????????????????? superdave2 Nitro Off-Road 19 08-15-2009 08:09 PM
Ineed a good 12V Battery Charger for my Starter Box!!!! NEMMITH Nitro On-Road 16 10-21-2002 07:35 PM
