Driveshaft pins replacement tool? >
Like Tree1Likes
Old 02-16-2011, 07:06 AM
  #16
Integra's Avatar
Ebay chain breaker is what ive used for years and have Never had a problem.
Integra is offline
Old 02-16-2011, 07:52 AM
  #17
chedda bob's Avatar
Location: Where the ego's are so big, people's heads can't fit in the door
Trader Rating: 149 (100%+)
Correction... Make that 4 available
chedda bob is offline
Old 02-16-2011, 08:23 AM
  #18
ecpete's Avatar
Trader Rating: 39 (100%+)
Do you have a link to which tool you bought? There are so many listed on Ebay. Thanks!
ecpete is offline
Old 02-16-2011, 08:57 AM
  #19
energyracing's Avatar
This will sound like a noob question but where do you buy the replacement pins?
energyracing is offline
Old 02-16-2011, 10:39 AM
  #20
losiguy69's Avatar
i replaced my losi pins with the mugen pins part #mugc0270 and mugc0271
scott
losiguy69 is offline
Old 02-16-2011, 12:19 PM
  #21
Thank you
Old 02-16-2011, 12:33 PM
  #22
Integra's Avatar
Here ya go,
http://cgi.ebay.com/MOTORCYCLE-ATV-C...item588caf2493
Integra is offline
Old 02-16-2011, 12:36 PM
  #23
xxxtcr's Avatar
Trader Rating: 15 (100%+)
anyone know if the mugen pins will work with the associated dogbones? Thanks.
xxxtcr is offline
Old 02-16-2011, 02:05 PM
  #24
fun hawg 1's Avatar
Hi I buy my pins from mcmaster carr hardened pins are like $7.00 for 50 of them and use a small press. I drilled a hole in some aluminum block to hold shaft and the old pin to fall out. super simple and cheap never broke anything.
fun hawg 1 is offline
Old 02-16-2011, 02:37 PM
  #25
Yes, they will.
Stealth_RT is offline
Old 02-16-2011, 02:58 PM
  #26
I would keep an eye on the out drives if you buy hardened pins.
I like the x-ray design better where,the pins are softer than the out drives.I like the pins to wear & not the out drives. $5 for 10 pins is a lot cheaper than $25 per out drive. I have been able to go 20 gal between out drive replacement when pins are replaced as soon as they show wear.
I can only recomend staying with factory parts simply from experience but x-ray says their pins are hardened, to what hardness I dont know but I do know that there is alot of incriments on a rockwell hardness tester so the word hardened doesnt really mean a lot unless you know the actuall #s your using.
Just something to keep in mind.
butch man is offline
Old 02-17-2011, 10:09 AM
  #27
what size and type of pin do you order? they have quite a selection.
dlawhorn is offline
Old 02-23-2011, 03:17 PM
  #28
Akhor's Avatar
Originally Posted by chedda bob
Or you can buy this one from me...
My boss and I are avid racers (hence check my other posts... we make all kinds of stuff) and we made a few almost identical to the Hudy one. Works the same way, all hardened parts, etc.
$65 shipped
BTW~ We have 5 of these I believe if anyone else is interested
Wow, this looks exactly like the Hudy one I have, but at a much cheaper price!
Paint it black and people with think it's the hudy!
Akhor is offline
Old 02-23-2011, 03:23 PM
  #29
golferdude1971's Avatar
Trader Rating: 18 (100%+)
Guys, Amainhobbies looks to be out of stock with the IDRC Bonsavers, but you can get them @ kingheadz.com.
Here is a direct link: http://www.kingheads.com/product_inf...ba31de57f178e1
The IDRC Bonesaver is a great product, and it's a very small tool to keep in your toolbox.
golferdude1971 is offline
Old 02-23-2011, 03:27 PM
  #30
Also, Mugen has two part numbers for replacement pins. MUGC0270(3x12.8mm) & MUGC0271(3x13.8mm).
I use the MUGC0271 pins on all of my Losi driveshafts.
