Old 02-14-2011, 01:17 AM   #1
Default JS Racing
hello there, any one have a new JS racing motor that they have some running in information that would help me out.i have run 8 tanks thru it at 1/4 throttle and havent adjusted any niddles yet.what is the best way to run them in?????
BLJNZ is offline   Reply With Quote
Old 02-14-2011, 01:34 AM   #2
malcnz's Avatar
Hi,
Did you buy it new? as H.O.T the NZ Importer includes very good run in instructions so follow that ...after 8x tanks you should have leaned it out some and also you need to run it with more throttle as the worst thing you can do is let them run cold as they need to get some heat into them...anyway read the instructions
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 02-14-2011, 07:15 AM   #3
Paul Snyder's Avatar
[QUOTE=BLJNZ;8649676]hello there, any one have a new JS racing motor that they have some running in information that would help me out.i have run 8 tanks thru it at 1/4 throttle and havent adjusted any niddles yet.what is the best way to run them in?????[/QUOT
You should start leaning your motor out on your next tank. Before you do that, set your idle gap to 1 and 1/4 turns out from closed. This will make tuning the motor much easier. After you set the idle gap you need to get the motor to idle(low speed needle) , and then set your top end. This technique is what all of us team guys use. If the motor ever become too far out of tune, just reset the idle gap and start over.
Clockwork racing Engines, S&W Fuels, Lucky 7 Team Driver, Majestic R/C Team Driver, Answer R/C, Fastlane Graphix, LCRC Raceway, First Turn Racing
Paul Snyder is offline   Reply With Quote
Old 02-14-2011, 07:22 AM   #4
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Well 8 tanks covers the most important part of running in. You should now start getting the motor up to around 200 degrees and run a couple more about 1/2 throttle then you should be good. Or if you want to get some practice in just throw it on the track making sure the temps are good, just keep it easy on the straights and don't go crazy with the rpm's.
awdcameolsx is offline   Reply With Quote
Old 02-14-2011, 07:23 AM   #5
http://www.rctech.net/forum/offroad-...js-engine.html
NitroOB4You is offline   Reply With Quote
EB Mods JS Racing "TX-521R" .21 Fully Modified Nitro Engine VS MASSIVE MODS MG66 emin007 Offroad Nitro Engine Forum 9 11-09-2010 05:21 PM
O.S. V-specs eng/New V-spec p/s/r/JS racing eng/rx packs/pipes/starter box... twt_07 R/C Items: For Sale/Trade 22 10-15-2010 02:05 PM
NIB EB Mods JS Racing "TX-521R VOX" Competition .21 Nitro Engine (Race Prep) Toiffel R/C Items: For Sale/Trade 21 07-27-2010 05:43 AM
EB Mods JS Racing TX-521R VOX COMP. Motor kodiakbear7070 Nitro Off-Road 86 05-05-2010 02:39 AM
