Old 02-13-2011, 10:19 AM   #1
wannarace's Avatar
Default Tire Question
I just bought my first set of AKA City Block (soft)tires, far better than the stock tires that came with my Losi Eight-T 2.0. My questions are these...
1)How long do tires like these usually last? What's the wear on them if I actually only used them on the track?
2)Also why do all the guys at the track have so many tires on hand of the same compound? Is cleaning them in between runs that hard?
3)Also whats the best way to clean tires after a days run?
Thanks for everyones help!
wannarace is offline   Reply With Quote
Old 02-13-2011, 11:52 AM   #2
camocowboy's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to camocowboy
Tire wear is gonna depend alot on the surface you are running on. If the track is loose, or loamy, you might get alot of run time on the tires. If it is higher bite it will wear them out faster in most cases. You should probably get at least a couple of weekends on your city blocks at the club level. You are seeing people with different tires at the track because different tread gives different handling traits, and at a higher level guys run new tires every run or at least put on a new set for the main. Best way to wash them is just run a little water over them and brush them off.
#92 Greg Singletary
Punched R/C Productions - Ascendancy Racing - Byrons Fuel - JGO Paint - The Nitro Pit - One Hobbies Shop and INDOOR RACEWAY
camocowboy is offline   Reply With Quote
Old 02-13-2011, 12:46 PM   #3
merdith6's Avatar
Default Yep
What he said.... but they will usually last a long time. More than a few races for sure...I'd say 8 race days..I do use dishsoap and hot water with a toothbrush, it brings back the sticky rubber like those wacky wall walkers.....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Panther Tire Question CJ RC Nitro Off-Road 16 03-17-2009 08:47 AM
Foam Tire Question??? NotSoFast Electric On-Road 15 08-13-2006 08:53 PM
Foam tire question- nomaak Electric On-Road 18 12-12-2004 07:19 PM
