Old 02-08-2011, 05:01 AM   #1
Default Losi 2.0 clutch help
Ok i bought a used rtr losi 2.0 and i have it striped down to bare chassis.I am rebuilding it ground up switching all the rtr stuff out with the race buggy parts shock towers,shock caps hinge pin brace's,etc,etc.That being said i am thinking of using the kingsheadz clutch shoes and need some help in understanding the spring colors and what to run? thanks for the help.
mfroot is offline   Reply With Quote
Old 02-08-2011, 07:09 AM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
A lot depends on what engine you are running. For the clutch I always ran king headz 6061 shoes with 2 green and 2 black but that's with a speed engine. Start with 2 green a d 2 gold and 2 alum and 2 composite shoes unless you like it real snappy. Then use all alum shoes. If the buggy feels to much like a rubber band when it takes off then go down to green and black sprigs. Black are the lightest then green, gold, and sliver are the strongest.
Btw what engine are you running?
Old 02-08-2011, 07:13 AM   #3
Suspended
Trader Rating: 202 (96%+)
what frank said ^^
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 02-08-2011, 07:29 AM   #4
I am going to be running the mach 427 its going to be modded and a re-11 pipe or a jp-2 which ever work the best. I know alot ppl don't run that motor so i want to see what i can get out of it. lol i like challenges.
Old 02-08-2011, 08:25 AM   #5
Frank L's Avatar
Start with 2 green and 2 gold and all alum 6061 shoes. Then if it's too snappy use 2 composite shoes and if it's still too snappy 2 green and 2 black with all alum. The softest would be 2 green 2 black with 2 alum and 2 composite.
I think that engine with 2 green and 2 gold with all alum or 2 alum and 2 composite would be perfect.
Old 02-08-2011, 08:28 AM   #6
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
Originally Posted by inferno13 View Post
what frank said ^^
yes what frank said he knows what he is talking about
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 02-08-2011, 08:38 AM   #7
Frank L's Avatar
Thanks. Some guys would say you are crazy but I ran these cars for awhile. I like the simplicity of the Losi clutch just too bad it dosent fit in much else without some serious mods.
Old 02-08-2011, 08:50 AM   #8
Default Help too
Hi frank, I'm kinda in the same boat as mfroot I too just got a losi buggy but I'm running a GRP Tune Line engine and I really don't know much about the losi clutch set up and what spring does what and all that I just want a good all around set up with a little snap....Thanks in advance...
Brokeagain is offline   Reply With Quote
Old 02-08-2011, 09:33 AM   #9
neobart's Avatar
The std. clutch setup works well with most engines, worked for me when I had a GRP in my buggy.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 02-08-2011, 09:46 AM   #10
Integra's Avatar
Gold and Green with alum and comp and your good to go. Its Imo one of the best buggy clutch's out there.
Old 02-08-2011, 11:03 AM   #11
Gold and green for me too, but I like it best with the all aluminum KHZ shoes. That's what's in my buggy right now.
Who the ^&@$#()! Is Jason Branham!?
cjtamu is offline   Reply With Quote
Old 02-08-2011, 05:13 PM   #12
Frank L's Avatar
The 2 green and 2 gold should work fine. If you want more snap out of the bottom end then try to change the green springs to silver one at a time.
Old 02-08-2011, 06:24 PM   #13
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Alot of guys will blow me up over this but trust me.... Try all losi composite with all green.. if thats not enough then go all gold with composite.. Your shoes, bell and bearings will last forever and depending on your engine should half plenty of rip......Acctually look closely at my avatar, thats not a slap wheely, thats just coming onto the straight away!
SCUBA STEVE is offline   Reply With Quote
Old 02-08-2011, 07:49 PM   #14
Suspended
havent had real good luck with any composit shoes, aluminum is the way to go with losi clutch.
Old 02-11-2011, 05:43 AM   #15
ALF420's Avatar
Trader Rating: 9 (85%+)
+1 your 100% correct
Set it like this guy said and your GOOD TO GO
Cold Fusion RC Products
www.fullthrottlerc.net Boonsboro MD "RIP"
ALF420 is offline   Reply With Quote
first to get losi 2.0 rtr buggy? fukitol Nitro Off-Road 114 08-20-2009 06:27 AM
Locking the flywheel so I can remove the clutch nut on Losi 2.0 Garet Jax Nitro Off-Road 26 07-07-2009 02:51 PM
