Z01-T body
Old 02-07-2011, 01:25 PM
Default Z01-T body
does anyone know of a bulldog body that will work on a z01-t
metalbart is offline
Old 02-07-2011, 01:54 PM
Trader Rating: 29 (100%+)
Default body
mbx6t is the best fit
Mdoc is offline
Old 02-07-2011, 02:43 PM
Stubbs's Avatar
Trader Rating: 58 (100%+)
I just mounted up an mbx6t bulldog.....the front body posts need to be raised, or the shock tower hits. I'm kind of.....meh, it's ok. I'll get a JC Punisher next.....maybe it fits better.
Stubbs is offline
Old 02-07-2011, 03:08 PM
jmaxey51's Avatar
from what ive heard the JC punisher body for the MBX6T is a perfect fit, no mods needed.
jmaxey51 is offline
Old 02-07-2011, 04:18 PM
StillH20 Racer's Avatar
Trader Rating: 26 (100%+)
I have the punisher body on my truck and it is a perfect fit. It just requires a little extra trimming. And to help get a little more airflow over the engine you can lower the rear mounts so they only use one screw. I'll take a few pictures of mine and put them up for you guys to see.
StillH20 Racer is offline
Old 02-07-2011, 07:04 PM
Thanks the pics would be cool to see i think ill order one and try it ill post some when i get it.
Old 02-08-2011, 07:51 AM
Default bulldog body
Stubbs, can you post pix of yours also ???
Mdoc is offline
Old 02-10-2011, 08:25 AM
Stubbs's Avatar
Here are a few pics of the MBX6T Bulldog on my Z01T
Stubbs is offline
Old 02-10-2011, 09:43 AM
looks great, and thanks for posting them
Mdoc is offline
Old 02-10-2011, 07:15 PM
Default STUBBS
WOW!!!!! Looks good i still want to see the jc body.
Old 02-11-2011, 05:57 PM
Here are the photos of my Z01T with the Punisher body.
Old 02-12-2011, 10:30 AM
Stubbs's Avatar
Yeah, I like the way that one looks better.....can you post a shot of your front body mounts? Did you have to move the front or rear at all?
I just had a chance to run mine in a race, well, practice anyway....race got called for low turnout. I'm not real happy with the bulldog. It's about 3/4" too narrow, hits the pipe, and the edge of the radio box. It just doesn't fit that great.
I've got a Punisher coming to try out. If it fits like the bulldog, I'll just stick with the stock body.
Stubbs is offline
Old 02-12-2011, 11:45 AM
The only thing I did witht the body mounts is move the rear ones. I used the bottom hole on the tower and used the top hole in the mount. It just makes it sit lower.
It actually fits around the chasis quite nicely. Doesn't hit anything like you say the Bulldog does. The only thing I'm gonna do with the next one is I'm gonna cut it so but the rear it goes as far back as the mud guards on the side. Other then that I love the way the body fits.
Old 02-12-2011, 12:05 PM
Trader Rating: 43 (100%+)
Both of those trucks look sick!!!!!
Brian Alderman is offline
Old 03-05-2011, 07:47 PM
Stubbs's Avatar
I just posted these in the Z01T thread, but I figured I'd put them here too, since my Bulldog pics are here too. Good for comparison...I changed the color scheme up a bit too. I think this may be my new combination. Even though I work for John Deere, the green & yellow was getting a bit old.
Anyway, the Punisher fit MUCH better than the Bulldog. It's the correct width to drop right down over the side pods, The body mounts are in the stock location, and nothing is rubbing.
For anyone mounting one on the O'Donnell, trim the body about 3/8" below the molded in body line. It will cover the side pods more, and looks much better. Other than that, it was just mount / mark / trim / repeat, until I had everything like I wanted it. Now I can use this body as a template when I do future ones.
Stubbs is offline
