-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   Plastic materail they use ? (https://www.rctech.net/forum/nitro-off-road/479805-plastic-materail-they-use.html)
leo griffith 02-07-2011 12:02 PM
Just woundering what plastic they use to make the componets on rc cars! I have a few projects i want to make! Thanks
merdith6 02-07-2011 12:17 PM
It's
Nylon. Sometimes they mix fibers in it to give it more ridgidity...
Racecrafter 02-07-2011 11:21 PM
All types...
ABS
Urethane
Nylon
Glass filled Nylon
Acetal (Delrin)
Graphite filled Nylon
Carbon infused Urethane
and the list goes on and on.
Roelof 02-08-2011 01:12 AM
If you want to make nylon parts I advise you to get something like these:
http://www.photonomikon.com/wp-conte...ting-board.jpg
Plastic chopping board
Bear_ 02-08-2011 05:20 AM
when rc car designer make parts using rapid prototyping, do they use nylon or other material ?
i heard that most car designer use the parts from rapid prototyping for testing as it is hard and tough enough.
Roelof 02-08-2011 06:10 AM
They use 3D printers which can actually create a working part, not as strong as you want it to be but good enough to make a test drive or just try to see if it fits with the rest.
Ruune 02-08-2011 07:16 AM
If you're looking to make things like A-arms, diff mounts, any sort of structural part, you should consider full-strength Delrin 100AF. It's a mix of Delrin polymer and 20% teflon. Low surface resistance and high strength. you can even machine it:
http://www.professionalplastics.com/DELRIN100AFSHEETROD
Racecrafter 02-08-2011 07:26 AM
Most cutting boards like the one pictured are made of UHMD.
We used sheets of UHMD for under body protection on Rally Cars (real ones).
Its very tough "plastic".
johnny t 02-08-2011 08:08 AM
buy some nylon 6/6 and go nuts.
