Old 02-06-2011, 12:36 PM   #16
Midwest_Mudder's Avatar
depending on how tight you have the screw, use either superglue or as mentioned quicksteel. if that doesnt work, can you get a pair of needle nose pliers on it? thats a much easier way to do things.
First in.... Last Out. Interior Rescue
I can barely keep track anymore....
Midwest_Mudder is offline   Reply With Quote
Old 02-06-2011, 12:52 PM   #17
http://www.amazon.com/dp/B001A4CWHO/...l_852vypfy66_b
These things are awesome and you do not damage any parts around the bad screw. Once the guys at the track used mine, you see them everywhere now. Great Product!
The 3 piece set is fine.
SPEEDSKI is offline   Reply With Quote
Old 02-06-2011, 01:04 PM   #18
i agree, those pro-grabbits are nice, there are tons of options out there. There are also some that look almost like a phillips screwdriver head, they taper, have razor sharp cutting edges and work great for anything small. Head bolts on the other hand tend to like to snap them. just head into your local hardware or farm store, explain to someone in there your problem, they're likely to have 3 or more options that will work great.
Old 02-07-2011, 06:17 AM   #19
rc skyline's Avatar
Originally Posted by Lapper View Post
Forget the screw and try turning the post. Or hold your allen key on an angle while turning the screw. Few different things to try.
+ 1
If it's a screw that can be left on its own after removing all others out of something like a radio tray just turn the tray instead with whatever you have that best fits the worn screw head holding it... Once you turn it the slightest amount you will then easily be able to undo the screw
Dave
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Old 02-07-2011, 06:28 AM   #20
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Originally Posted by rc skyline View Post
+ 1
Dave
lol the steering post cant turn
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 02-07-2011, 07:01 AM   #21
Pin2Win's Avatar
Trader Rating: 19 (100%+)
Dremel a slot in the head and use a flat tip to remove it easiest way and takes all of 5 min.
Nick "Sarge" Frazer
EPRC-Wichita KS|EPRC.club@gmail.com| www.emeryparkrc.com
Pin2Win is offline   Reply With Quote
Old 02-07-2011, 07:13 AM   #22
Trader Rating: 74 (100%+)
QFT...love this thing...only one I've ever used is the #1 which you can get from Lowes http://www.lowes.com/ProductDisplay?...77-41877-8501P
skerry1 is offline   Reply With Quote
how to remove stripped screws jjl5590 Nitro Off-Road 13 11-20-2009 09:07 AM
Removing Stripped Setscrews battlecat3 Nitro Off-Road 11 05-06-2009 04:23 PM
Stuck mounting screw rcburner Nitro On-Road 12 09-07-2005 08:49 AM
Stripped screws ........ how do you take them off ? asw7576 Electric On-Road 11 10-31-2004 04:48 PM
