Old 02-04-2011, 02:13 PM   #1
vti-chris's Avatar
Default Car settings with the most effect...
Can u post which setting u tried and know that had the most effect on the car handling...please try and put some in an order of which has the most and whix has the less impact on the car.
Apart from tyres!!!
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 02-04-2011, 02:19 PM   #2
bcr500's Avatar
Trader Rating: 34 (100%+)
Great post! I was thinking of asking the same thing lol.
MBX6R
XRAY XB808
NOVAROSSI
bcr500 is offline   Reply With Quote
Old 02-04-2011, 02:30 PM   #3
Send a message via MSN to helgso
On settings, are you meaning tuning of the engine or common settings on the chassis like shocks, gear shifting etc.?
On the tuning, leaning the engine (screwing the High Speed Needle clockwise = less fuel, more air, more power, higher temperature) most certainly gives more power, but lessens the engine's life. You will want to have the engine not too lean and not too rich (screwing the High Speed Needle counter-clockwise = more fuel, less air, less power, lower temperature)
On the shocks of the car, you don't want them to be too loose especially in races as you don't want the car bouncing like crazy. If you are doing jumps, you want to make very sure of this. Having the shocks loose when jumping might cause something to break in the landing as they give way too much.
Focus on having the shocks not too soft or hard.
(I'm not sure on this one, someone verify!)
On the gearing, making it shift later is good in sharp corners, as the car gets more acceleration = more speed to begin with. Making it shift sooner is good on straight sectors.
On glow plugs, colder ones supply more horsepower, hotter ones supply more speed.
Losi LST, Mach 427, JR servos
helgso is offline   Reply With Quote
Old 02-04-2011, 02:41 PM   #4
mister-e-meat's Avatar
check out the hudy set up book lots of useful information about what adjustments do what.
http://www.teamxray.com/teamxray/pro...b67dc5b06ce2fa
mister-e-meat is offline   Reply With Quote
Old 02-04-2011, 02:52 PM   #5
AZRC4Me's Avatar
In no particular order:
Ride height
Droop
Shock Oil
Shock Springs
Diff Oil
Shock Position
Sway Bars
Rear Hub position
Ride height and droop seem to be the easiest to adjust yet most effective tuning aids I've found.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Old 02-04-2011, 02:57 PM   #6
bcr500's Avatar
Im not trying to hijak this thread but i think what he was wanting to know as well as I is what makes the biggest changes to the least changes on chassie setup since alot of the stuff does the same things as others.i think it would go,diffs , shocks ,ride hight,droop, wheel base , roll center , acerman in that order.
MBX6R
XRAY XB808
NOVAROSSI
Old 02-04-2011, 03:14 PM   #7
IROC-AR15's Avatar
Trader Rating: 29 (94%+)
Send a message via Yahoo to IROC-AR15 Send a message via Skype™ to IROC-AR15
You should be more specific...Different settings work for different models...Like I dont use the same settings on my S-Maxx as I do on my Truggy!
IROC-AR15 is offline   Reply With Quote
Old 02-04-2011, 03:15 PM   #8
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
On my truck. Tires makes the biggest change. Oops. You saaid besides tires. Lol
Alan Hall
AlanHall is offline   Reply With Quote
Old 02-04-2011, 03:25 PM   #9
Busterlbn's Avatar
IMO oils gives the biggest change in car, next everything other.
Regards
Mugen Seiki | Novarossi | Futaba | AKA | Pro-Line | RB
Busterlbn is offline   Reply With Quote
Old 02-04-2011, 04:33 PM   #10
IROC-AR15's Avatar
Cool
Regards
It's really hard to answer this question for him...you're right though Tires and Diff Oil makes a huge difference....I suggest both you gentleman that are asking about settings google a setup for your particular buggy/truck, like I said every vehicle is different there is no set standard that will work all across the board....The Setup for my Thunder Tiger ST-1 doesn't necessarily give the same results on my S-Maxx 3.3
Old 02-04-2011, 05:32 PM   #11
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
This is kind of hard to answer since certain adjustments make bigger differences for certain situation (if that makes sense). Also, some adjustments can be really extreme and completely change the handling of the car. My recommendation is to read the Hudy set up book. It tells you what changes work better in certain conditions. As for me, I find a basic set-up that is "pretty good" everywhere and then make small adjustments to...
- Front Camber (More/Less Steering)
- Rear Camber (Stability)
- Droop (More - smooth track/less - rough track)
- Ride Height (depends on what you want, this can change a lot of things)
- Rear Camber Link (depends on what you want)
- Shocks (depends on temperatures and track conditions)
- Shock Rebound
- Anti-Squat/Kick-Up
There are so many adjustments, but my opinion is to find a set-up that YOU are comfortable driving, and then make small adjustments from there. To be honest, I consult my Hudy set-up book before I make any set-up changes.
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
CJ Weaver is offline   Reply With Quote
Old 02-04-2011, 05:34 PM   #12
dburt86's Avatar
i dont think hes asking for specific settings, but rather wich ones made the biggest changes.although it would be helpful to know what kind of rc he is talking about, truggy, buggy, mt.....
Excluding motor, it goes, for me
ride height
shock oil
diff oil
dburt86 is offline   Reply With Quote
Old 02-04-2011, 05:42 PM   #13
IROC-AR15's Avatar
ride height
shock oil
diff oil
My Point Exactly! Specify what you want to set up dude you'll get lot more detail replies but like the other dude said consult the Hudy Set Up Book for a complete understanding!
Old 02-04-2011, 08:05 PM   #14
j_blaze14's Avatar
sorry, #1 is always tires. oils probably 2, if any of the others are way off you will tell but just keep everything centered in whatever car and it should drive just fine.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 02-04-2011, 09:57 PM   #15
Of the easy to make adjustments that make the most change.
Ride height both total front and rear and the differential from front to rear.
Droop.
Both are easy to adjust and make a major difference in the handling.
Ed M.
bentgear is offline   Reply With Quote
The Speed Passion Thread memix Electric On-Road 13328 Yesterday 04:09 PM
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 07:57 PM
