Old 02-04-2011, 07:48 AM   #1
wannarace's Avatar
Default How do you recommend
Cleaning the GUNK and DIRT that accumulates around the glow plug and heat sink shaft. I want to make sure I clean it well before any loose dirt falls down the head when the glow plug is removed. I usually like to use some after run oil after my day at the track and find it scary removing the glow plug with so much dirt around the plug. Any ideas or suggestions???
wannarace is offline   Reply With Quote
Old 02-04-2011, 07:55 AM   #2
air compressor or a contact cleaner
RePeTe is offline   Reply With Quote
Old 02-04-2011, 09:34 AM   #3
wannarace's Avatar
So pulling the heat sink off is not recommended??? It looks simple (4 screws) however I never done it and not sure if its advisable to do...sorry for sounding noob, but I am and like to go about things correctly.
Old 02-04-2011, 10:02 AM   #4
Snowbum32's Avatar
Trader Rating: 33 (100%+)
When I clean my buggy I just pull my motor and clean it under the sink staying away from the cluth and carb of course, then take a compressor and dry the motor that way.
Snowbum32 is offline   Reply With Quote
Old 02-04-2011, 06:41 PM   #5
mx51's Avatar
Every time i run my trucks i blow them off with a compresser before i bring them in the house in my opinion thats the best way
mx51 is offline   Reply With Quote
Old 02-05-2011, 09:10 AM   #6
i hold the car upside down and spray the head out with denatured alcohal untill clean
Track mngr SliverFox R/C Raceway
clay is for pottery dirt is for racing
Turn left to go right...
markkris is offline   Reply With Quote
Old 02-05-2011, 09:25 AM   #7
shanty140's Avatar
You can pull the cooling head without a problem. Depending on your motor it will either have a head button that is separate from the cooling head, or the head button will be part of the cooling head. Most motors have the head button that is separate from the cooling head. The head button is what the glow plug screws into. For cleaning the head button your shouldn't really have to take the head button off. But I guess if you want to do a very good job cleaning. If you do take the head button off, make sure you don't lose the shims that be on the underside on head button. Most motors do have shims, but there are some lower quality motors that don't have any.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 02-05-2011, 05:09 PM   #8
wannarace's Avatar
This was the answer I was looking for...thank you. The motor is a Novarossi Plus 4, any idea if the cooling head and motor head button are attached or seperate? Looks to me as if its seperate from the top.
Old 02-05-2011, 06:15 PM   #9
shanty140's Avatar
They are separate and will have head shims.
Race Vehicles:
New to R/C Hobby, which one do you recommend me? enb141 Electric On-Road 14 01-03-2010 07:40 AM
New here - how do you charge your nimh packs? gini@BentKneeRC Rookie Zone 17 02-14-2009 11:15 AM
How do you plug this ps into a wall socket? JusBox Electric On-Road 207 04-30-2004 04:30 AM
What do you recommend to get started Slimsaturn Nitro On-Road 8 03-03-2003 07:44 AM
