Old 02-04-2011, 04:29 AM   #16
kgombe's Avatar
Originally Posted by mccutch12001 View Post
Now im really not liking these hubs. Cant tighten the screws on the knuckle because they will bind the movement Maybe i need a Losi......
they come with plastic spacers that you have to put in place to raise it up a litle off teh hub
kgombe is offline   Reply With Quote
Old 02-04-2011, 07:10 AM   #17
mccutch12001's Avatar
Yeah.....all i got were the hubs, two ballstuds that fit nothing, 4 setscrews and two "fixing balls" that i attatched the camber links to. I'm just putting the plastic ones back on and considering finding another car......i cant stand this cheap plastic and $50 hubs that dont even fit right much longer
Losi 8ight 2.0
Novarossi Plus 21-4C
Futaba 4PK Super
THE OHIO RC FACTORY
mccutch12001 is offline   Reply With Quote
Old 02-04-2011, 08:02 AM   #18
ScottyM's Avatar
Trader Rating: 27 (100%+)
Wash your mouth out with that talk.. We don't need no stinking Losi in here..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 02-04-2011, 08:03 AM   #19
ScottyM's Avatar
THE Cheap Plastic is very durable, and will last as long as your Losi plastics, maybe longer..
Scott Musgrave
Old 02-04-2011, 08:41 AM   #20
Hahaha, i'm just kinda beyond angry with this car at the moment.....i break at least one plastic hub every weekend so i get the aluminum and they are so poorly designed that they will not function correctly. I actually like the car most of the time. Probably wouldn't get a Losi anyway.....go with the Serpent instead! At this point i just figured it best to stop working on the car and put the new TKO ceramics in the B5
Losi 8ight 2.0
Futaba 4PK Super
THE OHIO RC FACTORY
Old 02-04-2011, 10:08 AM   #21
ScottyM's Avatar
I never had a plastic failure with my buggy or truggy, that I couldn't attribute to my own fault.. I am not trying to say you don't have a problem, but I'd liek to see your driving style, and set up. I have a feeling some changes might help you out..
Scott Musgrave
Old 02-04-2011, 10:35 AM   #22
kgombe's Avatar
same boat here... the plastic last me for ever and only replace them at the end of the season for peace of mind... i will only replace if it offers peformance advantage.. other than that plastic it is.... unless i get the hara rear hubs for cheap on ebay
Old 02-04-2011, 10:42 AM   #23
Jesse Robbers's Avatar
Send a message via AIM to Jesse Robbers
If the alum hubs or caster blocks are tapped to a 3mm thread, use the 'fixing balls' (has the hole in the center of it) on the outer end of the turnbuckle ballcup. You may also need a longer M3 screw, something about 20mm long or a bit longer I think. I prefer to sue cap head screws for this application, the head strips out less easily when torquing the screws down. Use steel screws, stainless is weaker than steel screws. You have the option to tap the hole to 4mm thread and to use the optional steel 4mm thread ball stud for more strength. The 3mm screw setup you can bend or break screws in hard crashes. The 3mm screws also bend/break a lot easier if you don't thread lock them and/or check them preventing them from backing out.
Bound up steering, can't help you with that. Either some part(s) are defective or not installed properly. I've never had my spindles bound up. You have the caster block, kingpin bushings, 4mm kingpin screws, and spindles. Check to see if your axles are rubbing anything. If using Tekno axles this might be the problem.
Sponsored by: O.S. Speed, KO Propo, Sidewinder, Tekin, Thunder Power, Lunsford, Skipgear.com, Fioroni, Avid R/C, GMK Supply, Competition Heat, Dialed Inc., LiveRC.com, DE Racing, CIG2O, ANDROID Nitro Runtime Calculator App
Jesse Robbers is offline   Reply With Quote
Old 02-04-2011, 11:00 AM   #24
willbe's Avatar
If you crank down the screws into the knuckles too tightly they will bind. metal, on metal, on metal.
I add blue loctite run both screws in and back off a hour or two. I havent touched them in 6 months. The plastic doesnt bind as if you crank down to hard it will strip.
Curts fast tracks and tube spikes are taking its toll on you. Next time it breaks, grab me, Jesse, Chad, who ever is around and lets see why you are have problems with that one spot.
Jesse is absolutely correct on the stainless vs steel strength factor. Stainless is corrosion resistant not stronger than normal steel.
Amain hobbies has the cap heads that he was speaking of.
Mine didnt come with the 4mm studs or I would have used those on the first version rear aluminum hubs.
HB D812, HB D8T, HB D812E, HB D413, HPI Blitz SC, Losi 22 & 22T
Special Thanks to:
HotBodies/HPI Racing, Upgrade RC, OS Speed, Sidewinder Fuels, Hitec
Proudly using: Spektrum DX4R, Viper-RC Electronics, Reedy Batteries, & Pro-Line
Cancer Sucks
willbe is offline   Reply With Quote
Old 02-04-2011, 03:39 PM   #25
Jeel's Avatar
Trader Rating: 16 (100%+)
Had the same issue. As Willbe suggested, I simply used locktite and backed off the screws and and 1/8th or so to relieve the mild binding.
Jeel is offline   Reply With Quote
Old 02-04-2011, 06:15 PM   #26
Something isn't right if you can't tighten the screw fully (kingpin screws) while it's still free. I should be at Curt's track tomorrow.
