Old 02-03-2011, 08:43 AM   #1
Default RC8B
Guys,
i am having issues with the front CVD's that are always getting bent. The suspension is free. They seem to be very soft. Is there any alternatives out there that can last longer? Looking for some help here...
Big_one is offline   Reply With Quote
Old 02-03-2011, 09:58 AM   #2
Charles Godwin's Avatar
Just 're-bend' them back into shape. They bend because after a landing the wheels might have been turned and that one tyre took load so it bent it.
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-03-2011, 08:30 PM   #3
i know ut its a pain... i was thinkin about some more resistant like the xray spring steel one if they fit.
Old 02-04-2011, 12:04 AM   #4
JsK
JsK's Avatar
They bend in two places, at the outdrive and at the casterblock. You can
run shorter outdrives like the MP9 ones and use a dremel to round off the
sharp edge of the caster block directly above the CVDs.
JsK is offline   Reply With Quote
Old 02-04-2011, 02:24 AM   #5
Default cvd
Originally Posted by Big_one View Post
Guys,
take a dremel and cut another mm in to the depth of the out drives front and rear and you can also grind down a little bit of the ball at the end of the cvd and it wont happen any more..the thunder tiger cvds are 1mm shorter but you can never find them anymore..this will help.especially if you start running the new arms and towers.
nitrofish24 is offline   Reply With Quote
Old 04-10-2011, 08:44 AM   #6
ted05's Avatar
bro any pic of it ??? pls post here thanks
ooooooooooooooo
ted05 is offline   Reply With Quote
Old 04-10-2011, 11:08 AM   #7
I have beat the crap out of my RC8 and SC8 for more then 2 and a half years no bent drive shafts.. You probably have to much droop or in other words the arms are going down too far..
Rickm is offline   Reply With Quote
Old 04-10-2011, 12:39 PM   #8
PTP Racing's Avatar
Bent driveshafts are very common on the RC8 and RC8T. I used to get upset and replace or try and straighten them but now I just run them. It doesnt seem to cause any problems.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 04-10-2011, 01:25 PM   #9
ronsand's Avatar
I posted this in a similar thread but it seems just as fit here also.
This is a common problem on the RC8. As long as everything else is built and adjusted properly you can try to reduce the epa (end point adjustment slightly).
Check that you are not using excess droop.
Have the car at normal ride height with arms about level. Adjust epa to where it starts to bind (steering block against C-hub) and then back it of somewhat (do the same for both left and right of course).
Check that there is no binding in the steering linkage, during the full suspension travel, as you turn the steering.
You can in addition, as mentioned above, dremel of a mm or so from the end of the dog bones and the grove in the out-drives.
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 04-10-2011, 01:49 PM   #10
DiZzYNaTiOn's Avatar
Trader Rating: 25 (100%+)
HAHA me too
www.filmmakerforum.org
RC8B3 - OS Speed .19 - S9352HV - 4PKS
DiZzYNaTiOn is offline   Reply With Quote
D8 OR RC8B??? kman16jr Nitro Off-Road 213 08-21-2010 10:38 PM
RC8 vs RC8B CClay1282 Nitro Off-Road 21 11-15-2009 08:23 PM
RC8B Fabulous R/C Items: For Sale/Trade 28 09-29-2009 07:11 PM
Associated RC8B -Electric bsmooth Electric Off-Road 45 09-22-2009 07:47 AM
Wanting to buy a buggy...RC8B or 2.0? JustinT22 Nitro Off-Road 27 05-12-2009 09:29 PM
