Old 01-31-2011, 11:29 AM   #1
Default Hot Bodies D8t upgrades
After doing some research, I want to improve my other D8T a bit and just want some verification on my choices.
1. Kyosho 2.3 & 2.5 sway bars
2. Kyosho offset steering rod ends w/ Kyosho 6.8mm balls
3. Kyosho lightweight 50T spur gear ( is this a drop in fit or do I need to buy other parts to make it work in my D8T ?)
4. Kyosho front center drive shaft (is this a drop in fit as well ?)
5. Anodized aluminum servo horns for steering & throttle
If I am correct, these simple mods should increase the performance and durability of my D8T to a competitive level. Please review my selections and add any advice and/or corrections as you like.
Thanks in advance
crazdgunman is offline   Reply With Quote
Old 01-31-2011, 11:55 AM   #2
willbe's Avatar
spur and the center drive shaft are not mandatory. I have a year on my center drives. Just fill them with grease and put a boot or heat shrink over the joint. Save the 0 bucks for tires.
HB D812, HB D8T, HB D812E, HB D413, HPI Blitz SC, Losi 22 & 22T
Special Thanks to:
HotBodies/HPI Racing, Upgrade RC, OS Speed, Sidewinder Fuels, Hitec
Proudly using: Spektrum DX4R, Viper-RC Electronics, Reedy Batteries, & Pro-Line
Cancer Sucks
willbe is offline   Reply With Quote
Old 01-31-2011, 12:04 PM   #3
Trader Rating: 100 (100%+)
If your looking to drop some weight, I've got a like new Tekno chassis and towers I will be selling. Looking to get half of new cost. PM if interested
ROSCOE is offline   Reply With Quote
Old 01-31-2011, 12:16 PM   #4
I'm not looking to drop weight as much as i am wanting to increase durability.
The stock chassis and shock towers are fine with me. My main concern is the front center drive shaft, hinge pins and steering. I can always compensate the weight with increased power via better/larger engine.
Old 01-31-2011, 12:22 PM   #5
diamondracing's Avatar
Trader Rating: 18 (100%+)
Thanks in advance
Besides the Kyosho sway bars & aluminum steering servo arm I would add aluminum rear hubs and aluminum front spindles after that it is pretty bullet proof.
Don "Truggy Tank" Tellefsen
Special thanx to: Mugen Seiki - Upgrade RC - diamondpainting.org - AKA Tires - NitroPro
diamondracing is offline   Reply With Quote
Old 01-31-2011, 12:39 PM   #6
Yep.......I thought about that too but will waite to see how the stock carriers/spindles hold up then replace them with the aluminum when needed.
Old 01-31-2011, 12:59 PM   #7
Tony Newland's Avatar
Trader Rating: 49 (100%+)
Thanks in advance
1. I always ran the stock say bars nad never wanted to change them
2. use the mugen or HB ends, then you dont have to buy balls as you can use the stock ones.
3. never had an issue with any of my stock spurs...
4. stock one will last a good half a season, then replace with the HB DCJ shaft
5. alum servo arms are a must have IMO
Alum rear hubs are a must have on the truggy
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 02-04-2011, 08:24 PM   #8
Check out our new Aluminum Wing Spacer Kit for Hot Bodies Ve8/D8/D8T. It shaves about 1 gram off (up high, creating a lower CG) and is stronger than the stock plastic spacer.
Only $15.99 from RPP Hobby
User Formerly Known As "LDRP"
Gear Head RC is offline   Reply With Quote
Old 02-04-2011, 08:34 PM   #9
GizmoJunkie's Avatar
+1
I would go aluminum from the word go and include those with your build. I had a stock plastic one shatter during practice in my first race day out with it... Glad i had something to run in a different class that day...
As far as the sway bars, if you get the right stock ones i would check those out first. My kit came with two rear (2.8) bars. I thought it was missing steering somewhere... I have since made my own front bar out of a peice of music (piano) wire, measured out at 2.36mm. Not sure how well this works yet as I havent run it since i installed it...
FT B4.1, FT SC10, FT B44; Tekin RS/Savox/D3's
HB D8/D8T - Werks/Buku/Savox
Airtronics
GizmoJunkie is offline   Reply With Quote
Old 02-05-2011, 02:50 PM   #10
brandundecided's Avatar
-1
brandundecided is offline   Reply With Quote
Old 02-05-2011, 10:06 PM   #11
Company Representative
ballisticsart's Avatar
Trader Rating: 20 (100%+)
+1 no more broken wing mont plates or crooked wings. important on a truggy which weighs alot and puts a ton of force on that rear mount during crashes
CFO - P1hobbies.com
P1raceway.com
Mercenary
ballisticsart is offline   Reply With Quote
Losi 8T 2.0 RTR vs Hot Bodies D8T mike881 Nitro Off-Road 166 11-28-2011 08:39 PM
Hot Bodies D8T Fully Upgraded..Lots of parts! sepukku R/C Items: For Sale/Trade 12 12-06-2010 07:49 AM
Hot Bodies D8T-E Electric Roller Truggy Fleshgearf150 R/C Items: For Sale/Trade 8 08-02-2010 09:24 PM
wtt wts Jammin x2 crt for Hot Bodies D8T will g R/C Items: For Sale/Trade 13 11-29-2009 09:14 PM
SEO by vBSEO 3.5.0
