1/8 nitro run away car
what is the proper way to help prevent a run-a-way vehicle do to loss of
signal to the reciever or battery dumps??? working with a Losi eight 4wd buggy thanks |
Originally Posted by jeff14346
(Post 8539633)
Go buy you a failsafe bro! Although it only helps if your signal drops. As far as the receiver battery goes, Ive seen people wrap a rubber band around the servo arm to pull the carb shut. I dont know of any other way, and you have to use a strong enough rubber band to overcome the servo! On another note, if you plan on upgrading your tx/rx, some come with a built in failsafe!
Sean |
just keep your receiver battery pack charged and make sure the connections are good and use a rubber band around the carb to close the carb if something goes wrong thats it.
+1 SMCCOLP
I use a failsafe on all of my boats and trucks. a 50+mph boat with a whirling prop is nothing you want to see heading toward people; and an equally fast car can sure bite an ankle hard:cry: |
(Post 8539633)
They sell these little black rubber bands at wal-mart in the hair care section. They are ponytail holders. About the size of a nickle or quarter, they vary. Anyway you can get 100's of them for a dollar. Been using them for a few years now, they are so cheap I replace them every time I do my clutch.
Spektrum receivers have a failsafe built in, you have to set it up. A little tip some people set the failsafe to full brake. If you do this your car will stop in the middle of the straight and you won't be able to get out of the way, it will get slammed into and somebody will be mad. Also if you ever turn your transmitter off and forget to turn off your car, in 20 minutes or so your throttle brake servo will melt from trying to pull your brakes for that long. So set it to neutral so you can coast to the nearest pipe. |
Originally Posted by Stickman!!
(Post 8541975)
here you go mate problem solved:D
http://www.rc-mushroom.com/product_i...ducts_id=19338 |
If you use the rubber band method, make sure you use the silicone ones. The ruber ones will deteriotate if fuel gets spilled on them.
thanks for all the tips :nod:
One aspect I see alot of people forgetting to check on their nitro cars is the electronics. When you tear your ride apart for maintenance check, and make sure all your connection are clean, make sure wires have not been partially cut. Make sure when you connect wires together, the two connectors (male/female) go together tightly. Any wobble or bad connectors, change!!!!! Make sure batteries in the transmitter is good. Dont try to save a buck and try to run your radio with weak batteries, same with the receiver pack.
If you wanna know how quick your car really goes, then let it run away, they always seem to be alot faster during a run away than at any other time :lol:
I use the reciever failsafe (Sanwa mqq 2.4 ghz) and carb O's to shut the throttle. IMHO if you buy the best radio gear and make sure all your connections are good and change ya battery regularly, you would have to be unlucky to get a run away. I still believe that the best failsafe is good maintainence. |
