Old 01-24-2011, 11:18 PM   #46
shanty140's Avatar
Originally Posted by JAMMINKRAZY View Post
I personally use a switch. There's plenty of reasons not to, but if you mount them properly, use a dust cover, and replace them often you won't have any troubles. I've used both methods and the switch is much easier to use for you and your pit man. I'd rather change the switch every couple months than run a lipo dead or fry my servos by leaving the battery plugged in all day. Use good switches and they last pretty long. This is one electronic item that I think JR has down. The JR small switch is great(unlike the rest of their products!).
What's the difference between forgetting to unplug a battery and leaving a switch on? If your going to forget to unplug a battery, your going to forget to turn a switch off. So I don't think a negative to not running a switch is forgetting to unplug the battery.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 01-25-2011, 02:06 AM   #47
Roelof's Avatar
Send a message via ICQ to Roelof
just for the electronic builders:
http://www.eleccircuit.com/one-butto...93-and-irfz44/
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is online now   Reply With Quote
Old 01-25-2011, 08:08 AM   #48
Integra's Avatar
Old 01-25-2011, 08:51 AM   #49
Exxaaaactly...
Mike Brotherton
VP-Pro USA - http://www.raceVPpro.com
Agama USA - http://www.AgamaUSA.com
Byron Fuels-http://byronfuels.com
MB75 is offline   Reply With Quote
Old 01-25-2011, 09:32 AM   #50
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I don't know about you, but when I'm done racing I go out to marshall the next race like I'm supposed to. Meaning my pit guys have to take care of the car. It is easy for them to flip a switch off. Not so easy to find the plug and unplug it. Like I said I've tried both ways and the switch is much easier.
I think people blame switches for problems way too often. What some people don't realize is just like the rest of your car there are parts of the electrical system that need to be maintained too. I don't see how switches can cause any problems if you just maintain them.
Switches turn off in a bad crash? Easy solution, buy a decent switch that has some "snap" to it and mount it properly.
You guys can argue about this all you want, but take a look at the Pro's cars. You think they would really be running switches at the WORLDS if they were such a problem?
Sure I've had switches fail, but it wasn't the switch's fault. It was mine for leaving them in there for a year and thinking they should last that long. They're 5 dollars. Replace them often. Or play around with your little plugs. I don't care what you do. If you like fumbling around with little connectors then you shouldn't run a switch. If you're a normal person, run a switch and replace it every now n' then.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 01-25-2011, 09:52 AM   #51
SteveBOX360's Avatar
The last sentence is hilarious!
"If you're a normal person, run a switch and replace it every now n' then."
Losi 8ight-T 2.0/ Novarossi Plus 4 21-4 Team / KO Propo 30101 / Airtronic M11x
SteveBOX360 is offline   Reply With Quote
Old 01-25-2011, 10:10 AM   #52
shanty140's Avatar
LOL lots of racers where not running a switch at the worlds. For example Savoya doesn't have a switch in any pictures I have seen. And if you have the plugs setup right, it should be in the exact same place the switch would be. So if you can't find the plug, I have no clue how to respond to that but you may have bigger problems then how to wire you vehicle. And if your pit man knows how to start and fuel your vehicle. Unplugging a battery should not be any harder then turning a switch off. Switch's can fail at any time even if they are new. For example the switch I had in my MBX6T last year had 2 tanks on it. I was lucky and it failed during practice.
All I am saying is a negative to not running a switch shouldn't be forgetting to unplug a battery when people can forget to switch off there vehicle.
Race Vehicles:
Old 01-25-2011, 10:33 AM   #53
neobart's Avatar
I don't see what's so hard about telling your pitman "yank this plug apart".
I think we can find better things to argue about, really. Like who has a bigger.........
.....Pitbag.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 01-25-2011, 10:41 AM   #54
shanty140's Avatar
I love my pit bag. It's average size but does the job very well.
Race Vehicles:
Old 01-25-2011, 10:49 AM   #55
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 01-25-2011, 10:54 AM   #56
omarwashington's Avatar
thats what she said
RCCARS!
omarwashington is offline   Reply With Quote
Old 01-25-2011, 11:45 AM   #57
JP4
This has been topic of debate a few times in our pits. I go switch-less here(after a few switch failures) and have for a couple of years now...but its not without issues. The Pit guy problem is the most common. I had a runaway 1 time from my pit guy not plugging my battery in all the way. Also...if you plug up while the body is clipped in...you will eventually crack your body.
I'm not for or against either way...but you have to use your head and turn your switch off or unplug it after the race.
For you Switch guys....What are some good switches out there? Please include brand and part number if you have it..I'm always open to returning to "normalcy"
JP
Jamey Powell
onpointrc.com / raceaka.com / byronfuels.com / reds-racing-usa.com / hcrcr.com
JP4 is offline   Reply With Quote
Old 01-25-2011, 11:53 AM   #58
neobart's Avatar
What's wrong with being special?
I like riding in the short bus, plenty of room.
Old 01-25-2011, 11:53 AM   #59
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
No switch here. They suck and always go out at the wrong time. I have had 3 or 4 go out, No more. Just plug it in and forget about the switch!
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 01-25-2011, 11:53 AM   #60
I use the standard JR small switch. Never had one fail. Never had one turn off. Haven't had a runaway in years. Don't plan on ever having one. Don't plan on ever removing the switch.
Pit guys have enough to be thinking about during/after a race. I'd rather make life a little easier on them. Being that I pit for a bunch of guys myself, I know what it's like trying to remember everything. If having a switch makes their job a little easier, that's what I'm going to do.
-Koby Kubrin-
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
