Old 01-16-2011, 11:54 PM   #1
deadmancourt's Avatar
Trader Rating: 11 (92%+)
Default Ofna MBX Ultra Comp
ok new question....does any body have any setup sheets or reccomendations on shock oil and diff fluids?...thanks guys
Rob Schneider
Special Thanks To:
S&W Fuel~Agama Usa/HobbyProUsa.com
RcRenew.com and TritonRc.com~Lucky7~Eazyrc.com
Venom-Group~Upgrade-Rc and TrackstarRc.com
deadmancourt is offline   Reply With Quote
Old 01-17-2011, 12:00 AM   #2
tc5 man's Avatar
nitrohouse should have them .
Old 01-17-2011, 12:08 AM   #3
have what?....what am i looking for?....what mounts will work?...the only ones that they say are FOR this buggy are the RTR mounts...which i already have
Rob Schneider
Special Thanks To:
Old 01-17-2011, 12:15 AM   #4
tc5 man's Avatar
i looked at nitrohouse and clicked on the car parts for the ofna mbx ultra comp and heres the only ones i saw.
maybe the hyper 7 or the other ofna buggy models that have non pullstart mounts will fit .
Old 01-17-2011, 12:19 AM   #5
yeah...dang $47 for the NON RTR mounts...thats insane..yah thats why i posted here to see if anybody knows what will work...i know people arent paying $47 to mount a NON pullstart engine in a mbx ultra comp.
Rob Schneider
Special Thanks To:
Old 01-17-2011, 01:32 AM   #6
The Ultra Comp. I used to have one of these. The first 8 scale i had. That thing was dam near bullet proof. I don't remember ever breaking anything on it and I bashed it on bmx tracks.
No starter box for me though. I wasn't that advanced yet. It was all pull start. old school baby.
I made this a truggy by putting on larger wheels and changing the gearing before truggies existed. Back then truggy was a modification.
Franchise is offline   Reply With Quote
Old 01-17-2011, 03:44 AM   #7
Trader Rating: 14 (100%+)
http://www.nitrohouse.com/p12271/ENG...7cc9cc3ea0aadf
http://www.amainhobbies.com/product_...d-Engine-Mount
http://www3.towerhobbies.com/cgi-bin...?&I=LXLMY2&P=7
If you can, measure the distance between the 2 chassis mounting holes on one of the stock mounts. I have a Jammin X2 and X1 and the distance I got is 0.944" or 24mm.
The stock mount for the Ultra buggies is listed to also work on the X1 so the above mounts should work. They probably don't list the Ultra buggies compatible with the above mounts because it lowers the engine too much and hits the chassis so you may need to add some shims between the mount and the engine.
http://www.amainhobbies.com/product_...e-Mounting-Kit
Chris
Jammin X2 CRT Pro - Tekno, Xerun 150a & Tekin 2250kv
Jammin X2 CR Pro - Tekno, MMP & 2050kv Tekin
Jammin SCRT10 - MMP & Tekin SC4X 6.5 | Ofna JL10e - Novak Havoc 3s & 8.5 SS Pro
HPI Cyber 10b - Novak Havoc 3s & 8.5 SS Pro | HPI Baja 5B SS - 26cc Fuelie
drummin89 is offline   Reply With Quote
Old 01-17-2011, 10:32 AM   #8
-R2-'s Avatar
these two parts work for RTR engines in a comp,
40674 and 10040
The 10040 is a large diameter flywheel for rtr engines, since the pull start hangs lower than the engine you cannot put on non pull start mounts. so look at your flywheel and measure it. Or you can look at it on a table. when you put it on the table the engine should be tilded alot because the flywheel is large, if it's close to sitting flat on the table then you have a non- pull start flywheel and need to go to the biggier dia. flywheel 10040.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 01-17-2011, 12:47 PM   #9
it has a small flywheel and it came with the ez start not the pullstart but it sits just as low....im not worried about mounting the motor that came with it....i just need a normal set of NON RTR/PULLSTART mounts that will work...i will measure to see if the other mounts mentioned will work...thanks guys....its weird to think this buggy was meant to run pullstart ect. only and not a bump box
Rob Schneider
Special Thanks To:
Old 01-17-2011, 09:52 PM   #10
are you sure you got these measurements...24mm? im getting a measurement of 2mm or 1.7 inches
Rob Schneider
Special Thanks To:
Old 01-18-2011, 02:17 AM   #11
yeah
1 millimeter = 0.0393700787"
24mm = 0.9448818888"
Chris
Old 01-18-2011, 10:05 AM   #12
-R2-'s Avatar
You said it had an e-z start or electric starter then there's your problem, the engine and motor mount have a spacer between them to have the flywheel away from the chassis line, that spacers brings it up 4mm. So I can see why the flywheel would not tought the doughnut on the box.
Old 01-18-2011, 11:59 AM   #13
sorry i misread your post and it didnt make sense...but after reading it 10x...it makes sense...i just need a bigger flywheel and run the RTR mounts will less shims....if i take out the 2 shims on the engine mounts, they will not let the motor sit flush on the mount...so i guess i have to run the 1 shim and bigger flywheel....sorry for the smart remarks guys...it was frustrating the hell out of me
Rob Schneider
Special Thanks To:
Old 01-18-2011, 12:56 PM   #14
last post edited ^^^^^
Rob Schneider
Special Thanks To:
Old 01-18-2011, 05:21 PM   #15
new question!...check first post ^^^^^
Rob Schneider
Special Thanks To:
OFNA ULTRA COMP LX MBX BUGGY 1/8 SCALE RACE SETUP 26 28 killatoyota4569 R/C Items: For Sale/Trade 7 07-06-2009 05:31 AM
