Old 01-11-2011, 06:40 AM   #1
traxxas-owns's Avatar
Default tire glue
what is the easiest way to put tire glue on tires without making a mess?
traxxas-owns is offline   Reply With Quote
Old 01-11-2011, 07:03 AM   #2
Practice makes perfect, no short cut here...
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 01-11-2011, 07:07 AM   #3
claycity's Avatar
also youtube it some good vids on there
Y.M.H. Racing
"IF WE DIDN'T RACE, SOMEONE ELSE WOULD BE LAST"
Build it idiot proof and the village builds a better idiot.
THE HILL AT COURTNEY IS NOW AT http://www.2kboffroad.com/themudpit
claycity is offline   Reply With Quote
Old 01-11-2011, 07:23 AM   #4
jammin32j's Avatar
Try this http://www.absolutehobbyz.com/produc...oducts_id=4072 It works great, but is only good for 1/8 buggy.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 01-11-2011, 07:49 AM   #5
Suspended
Trader Rating: 202 (96%+)
yep, practice...practice....practice, after you glue you fingers together or get stuck to your tire, you will learn to be more careful
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 01-11-2011, 08:05 AM   #6
rangerjkb's Avatar
Trader Rating: 38 (100%+)
Send a message via MSN to rangerjkb
Place tires on wheels. Put on tire bands/rubber bands/tape, etc. Use top quality (Fusion, AKA, Losi, etc) thin tire glue. Pull back bead and apply tire glue sparingly and release. Continue around tire bead ensuring entire bead is glued to wheel. Wipe away excess glue, if needed with a rag or towel.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is online now   Reply With Quote
Old 01-12-2011, 05:27 AM   #7
mattozx6rr's Avatar
Trader Rating: 15 (100%+)
Biggest and most important part of gluing tires is prep! rubbing alcohol is all thats required. Clean the beads of the tires and the rims well. install the tires so they are seated properly. pull bead back and apply glue. make sure every time you pull the bead back it reseats right immediately. after you have applied the glue all the way around install either a tire band or electrical tape around the edge of the tire to hold the bead in place. I use loctite professional ca glue. never had a tire release with this glue. if there is extra glue around the bead you can use a paper towel soaked with alcohol to wipe it away. Practice Practice Practice!
1 X MBX6T plus 21-4c
Twisted Bones R/C apparel
mattozx6rr is offline   Reply With Quote
Old 01-12-2011, 05:50 AM   #8
drewmugx5t's Avatar
Trader Rating: 21 (96%+)
I use the lactate professional glue as well it is the one in the blue bottle at lows or HD. It has never failed me and is easier to get than rc branded glue.
TeamXtremerc.com
MBX6-XZ-B Speed, MBX6T-Ninja, Hitec, Savox, Futaba 4pk
drewmugx5t is offline   Reply With Quote
Old 01-12-2011, 05:50 AM   #9
jmackani's Avatar
Trader Rating: 14 (100%+)
Proper prepping and buying the right glue with the right applicator. No need to spend money on those things that pull the bead back if you have the right applicator. Losi and AKA both now sell glue that comes with a tip that looks like fishing line and it is so much easier to apply. I used to always get glue on my thumbs previously without this type of tip. If you do not have the tip, then by all means go out and buy a tool to help. The applicator is LOSA7879 if purchased seperately. Losi tire glue comes with the applicator.
jmackani is offline   Reply With Quote
Old 01-12-2011, 06:07 AM   #10
shanty140's Avatar
+1 on this!
I would also add to prep the tires and wheel with denatured alcohol. And then keep practicing this over and over again. It's a bit difficult at first, but you will get better. Plus learning this task will save you money from not having to by Pre-mounts over and over again when with most newer tires come with foams that last a long long time. I haven't worn out a set of AKA foams yet. And they have actually gotten better then more I have used them. I have about 4 cycles on one set of truggy foams. I would rather run those then new ones.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 01-12-2011, 06:27 AM   #11
aussies1129's Avatar
Trader Rating: 74 (100%+)
thats about it
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 01-12-2011, 08:27 AM   #12
rcgeezer's Avatar
Buy pre-mounted tires! This way you don't have to mess with any glue, and if you shop around you can usually get a comparable price when you consider tires, rims and foams.
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 01-12-2011, 08:36 AM   #13
Bigedmond's Avatar
Trader Rating: 18 (100%+)
I never ever use rubbing alcohol. It has to many minerals, that is why i only use denatured alcohol. As for glue, its AKA only. It is the only glue that i have found that works every time. Just make sure to put the glue back in the fridge when you are done with it to keep it fresh.
Bigedmond is offline   Reply With Quote
Tire Glue Choices - Which offers the best value? Armaan Electric Off-Road 112 05-06-2014 03:22 AM
tire glue supertool28 Nitro Off-Road 49 03-10-2010 08:27 AM
Tire glue xxxtcr Nitro Off-Road 41 09-06-2009 11:51 AM
need some info about tire glue evader-fan-69 Nitro Off-Road 7 01-29-2009 09:45 AM
