Lipo Battery Checker
Not sure what you call it. What is everyone using to test to see how much mah is left in your Lipo battery.
I use the Dynamite Ultra Passport as my charger and thought that there may be a way that the charger could tell how much juice is left in the battery after using. Either I cant find out how to do it or it just does not have the capability. If it does not have the capability what should I use to test so that I dont get to low. Thanks everyone |
Originally Posted by dishsoap
(Post 8468735)
I use the Dynamite Ultra Passport as my charger and thought that there may be a way that the charger could tell how much juice is left in the battery after using. Either I cant find out how to do it or it just does not have the capability. If it does not have the capability what should I use to test so that I dont get to low. Thanks everyone http://www.okhobby.com/product.php?id_product=884 http://www.hobbyking.com/hobbyking/s...dProduct=10952 and http://www.hobbyking.com/hobbyking/s...idProduct=9282 |
I use the Dynamite Sentry to test my Li-Po and Ni-MH receiver
batterys. It has a test mode that applies a load to the battery and gives you readings of the amount of charge left in the battery, with a bar graph and voltage reading. Here is some info about it, http://www.dynamiterc.com/Articles/A...ArticleID=1740 |
I check my receiver pack with this: http://www.amainhobbies.com/product_...attery-Checker This one also tells you how much capacity (in %) you got left on the battery.
Originally Posted by gabor szilagyi
(Post 8469552)
http://www.okhobby.com/product.php?id_product=884 |
Wow!And i thought Hyperion came up something new idea!So they just copied....By the way i got the hyperion one from the local hobby shop for 24.99$ (still higher).Amain is little higher on this one...
Voltage checker's only tell you soo much, The only REAL true way to see how much Mah is left is to.....well charge the pack and see how much it takes....Once you get used to how many Mah you're taking in a particular amount of time can you then start to determine how much "juice" you got left.
(Post 8469948)
http://www.rcgroups.com/forums/showthread.php?t=1271384 |
