Old 01-08-2011, 09:39 AM   #1
Default Hot bodies problem
Hi everyone i have a hot bodies lightning stadium pro and for some reason when i try start it the engine seems to pop for ages before it starts and even when the car has been running when its warm it takes me ages to re start it again. Is there anything i can do to make it start easier. Hope someone can help me as its really frustrating me cheers
manic_mike is offline   Reply With Quote
Old 01-08-2011, 09:46 AM   #2
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
Well thats not a "Hot Bodies" problem thats an engine problem. Normally poping before starting and hard to start is a bad glow plug, also no wanting to start is a bad glow plug. Could also be a tired engine on its last leg. Whats the compression feel like when you try to turn the flywheel, if its tight its still good not so tight means the engine is really tired or shot. Also how hot are you letting it get, a proper tune can help it run better and always when done running put the engine back to bottom dead center. You do this by spinning the flywheel with ur hand to the most loose spot you feel(it's the bottom). You do this because when the metals are hot they expand and when cool they shrink back down. You want the piston to cool at bottom to insure longevity of the engne and it will keep it running longer.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 01-08-2011, 09:54 AM   #3
Hi cheers for reply its tight when i turn the fly wheel i will try putting new glow plug in and trying your suggestion cheers
Hot Bodies D8 Truggy Greg B Nitro Off-Road 10028 08-16-2017 05:44 PM
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
