Old 01-06-2011, 09:14 PM   #1
Default DNX408 setup
Im searching for some setups for the dnx408. I have looked and i have had no luck. I have not searched the exsisting durango threads because they are alot of posts and I am very busy from which I have not had the time. This should be very helpful for others in my situation also. Thanks for you help.
bigde2001 is offline   Reply With Quote
Old 01-06-2011, 10:09 PM   #2
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
there are a couple os setups on the durango web site! savoya has one out and so does luts.. all though they seem a little out there for me just dont know. But they are the pros so should work out.
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 01-06-2011, 10:17 PM   #3
I agree , that why I was wanting more input.
Old 01-06-2011, 10:30 PM   #4
transplantlife's Avatar
Trader Rating: 43 (98%+)
Heres one of Lutz's note this for indoor
Front shocks 6x1.3mm / 600cts, Red spring
Middle hole on tower, inside on arm
Front camber-link Middle hole/ inner row on tower
Hingepin spacer behind front arm.
Frontdiff 15,000cts
Camber -2
Height 27.5mm
2.1 swaybar
+1.5* toe out
10* caster blocks
Centerdiff: 12,000cts
Std Spur, 13T bell
Rear shocks 6x1.3mm / 600cts, Green spring
Shock Middle hole on tower and outside hole on arm
Rear link center hole on hub, inner row one up from bottom on tower
0 deg rearhubs, hubs centered
Rear arms all the way forward
Reardiff 6000cts
Camber -3
3-2 toe/kick-up insert
Height 27.5mm
2.8 swaybar
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 01-07-2011, 02:45 AM   #5
TeamDurango's Avatar
You can find DNX408 setups here -
http://www.team-durango.com/in-the-p...002&country=us
TeamDurango is offline   Reply With Quote
Old 01-07-2011, 05:31 AM   #6
t8rtot's Avatar
Trader Rating: 14 (94%+)
Just search in the Durango thread for "setup", its better for you to do the leg work and keep all the info in one place then to have 15 separate threads for each chassis, I searched it and found 6-7 on the 1st page alone, I doubt this will stay on the 1st page with the main thread so this will keep it cleaner and organized. Just trying to make it easier for everybody...
Sfida
t8rtot is offline   Reply With Quote
Old 01-07-2011, 11:54 AM   #7
bcr500's Avatar
Trader Rating: 34 (100%+)
Hey Deon let me know when your going to be at your track testing that buggy.I would love to come see what it looks like on the track!!
MBX6R
XRAY XB808
NOVAROSSI
bcr500 is offline   Reply With Quote
Old 01-07-2011, 08:12 PM   #8
sure will buddy
Old 01-07-2011, 08:43 PM   #9
explain to me how to do the search so I can the 6 to 7 set ups on first page.
Old 01-08-2011, 06:35 AM   #10
t8rtot's Avatar
Ok... In the upper right hand side of the page on the main DNX forum there is a search button, click on it, type what u wanna search, and KaBoom! setups!
Sfida
Old 01-08-2011, 07:47 PM   #11
Thanks man, searching it right now.
Old 01-09-2011, 09:22 AM   #12
t8rtot's Avatar
No problem, if you have anymore questions you can pm me or anybody else and we'll help u out no problem
Sfida
Old 01-12-2011, 06:47 AM   #13
Trader Rating: 235 (100%+)
Iam sure i missed this. But what is everyone running for droop?
Er8sr is offline   Reply With Quote
Durango DNX408 - Fast enough to win the World Title. TeamDurango Nitro Off-Road 10039 01-28-2017 01:01 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
JQ The Car or DNX408 oghobavo Nitro Off-Road 133 01-27-2011 10:09 AM
Team Durango DNX408 Prototype MaTt 93 Nitro Off-Road 1274 01-01-2011 12:48 PM
