Old 01-03-2011, 04:22 PM   #1
Default diff fluid change
hello im new 1/8th and im changing my diff fluid in my rc8t for the first time am i suppose to replace the gaskets? they didnt leak before but i didnt know if its common to change them?
RC8T /spektrum /prol-line/jconcepts/
Jerrys R/C raceway
jenson40 is offline   Reply With Quote
Old 01-03-2011, 04:25 PM   #2
hyperc10's Avatar
Send a message via Yahoo to hyperc10
You do not have to replace gasket unless it rips when removed, just make sure surface area is clean and cover it lightly in fluid when reassembling.
hyperc10 is offline   Reply With Quote
Old 01-03-2011, 04:27 PM   #3
thanks
Jerrys R/C raceway
Old 01-03-2011, 04:29 PM   #4
morgoth's Avatar
No, I've been running the same diff gaskets for 5months now. I replace them when they break.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 01-04-2011, 01:54 AM   #5
MCR82's Avatar
I have found in the past it is not always the gaskets that will leak, I too have been running the same gaskets for a while now with no issue, however, inspect the rubber "o"rings, the tiniest of splits can cause the diffs to leak.
MMI - RC Hobbyzone - Mugen Seiki - Neo + Fuels - AKA Australia - M2C - Phoenix Hobbies
MCR82 is offline   Reply With Quote
Old 01-04-2011, 03:33 AM   #6
shanty140's Avatar
As long as the gasket isn't damaged it will be fine. Gaskets are cheap, so if there is any doubt they are not in good shape change them put. Also check to make sure the rubber O-rungs are in good shape and not swollen. After awhile they can swell and make diff rebuilding a pain.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Changing diff fluid mccutch12001 Nitro Off-Road 15 12-17-2010 08:01 PM
Diff fluid set up dishsoap Nitro Off-Road 16 03-03-2009 08:19 AM
