Old 01-03-2011, 01:52 PM   #1
Default flipping in turn!
My back yard track is set up to get practice for just about every race situation. I have long a straight, woops, rough spots, tricky jumps, and some tight turns. In one of my turns I seem to flip over about 2 out of five times so I started to slow down and hit the turn different than before and still the same result. This turn is no worse that some on most tracks is there any thing I can do to the suspension to help with this? I am wanting to move from bashing to racing this spring and the fine tuning of the set up is new to me and any help would be great. Thanks
I may not be a racer, but I have just as much fun!!!!
LOSI 810, OFNA MBX comp a.k.a TURD, traxxas jato.
Dave.540 is offline   Reply With Quote
Old 01-03-2011, 02:56 PM   #2
Your probably "catching a rut" with your wheel and that's what's causing you to flip. I suggest adding 1 degree of negative camber to the rear. This should help.
Nicholas Schweiger
Mugen MBX7/Alpha Dragon/Radiopost TS401
DNX408 (waiting on parts so it can be sold)
NCS Custom Paint Works
Nick411 is offline   Reply With Quote
Old 01-03-2011, 03:16 PM   #3
Too much side bite? Does it do this will all types of tires?
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 01-03-2011, 03:28 PM   #4
merdith6's Avatar
Default Try
Try lowering the rear droop and ride height just a bit...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 01-04-2011, 01:50 AM   #5
MCR82's Avatar
+ 1, I have always found adding more negitive camber eliminates this problem.
MMI - RC Hobbyzone - Mugen Seiki - Neo + Fuels - AKA Australia - M2C - Phoenix Hobbies
MCR82 is offline   Reply With Quote
Old 01-04-2011, 03:30 AM   #6
shanty140's Avatar
Try limiting the droop and add negative camber and that should help the traction rolling.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 01-04-2011, 05:41 AM   #7
gabor szilagyi's Avatar
Reasons can be:-ride hight too high,-need more negative camber,-too much side bite (not the right tires,tire outer edge has too much bite)If u using a crime fighter tipe tire make sure u cut the outer pins in 45 deg angle,-too much droop,-u r too fast in the turn.Just the same info what the other folks said...I am jealous because u have your own practice place!J/K
gabor szilagyi is offline   Reply With Quote
Old 01-04-2011, 06:46 AM   #8
morgoth's Avatar
If you surface is grass, get thicker rollbars (but I doubt you track is grass?)
Try other tires, more neg camber, slighty thicker swaybar maybe, shorter camberlink in the rear, lower ride height.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Family Hobbies On & Off Road Racing In San Diego Jon Kerr Racing Forum 10726 09-11-2009 10:29 AM
Indoor Dirt Racing @ RC Performance in Madison squirrel Wisconsin & Illinois Racing 4856 05-11-2008 05:25 PM
MOJO RACEWAY in Alexandria Va MOJO Racing Forum 143 05-04-2006 02:16 PM
