Old 01-01-2011, 08:56 AM   #1
18SS's Avatar
Send a message via MSN to 18SS
Default HB D8T HELP
so my D8T is now acting up
my breaks are WEAK
someone out there must no how to strengthen the breaks on a D8T even if i have to buy parts for it or something im in need of help.
i first had it set up the stock setting as it tells u in the book. but now those settings dont give me full strong breaks like they used to.
my break disks are good and so are the steel pads.
what do i do ?
18SS is offline   Reply With Quote
Old 01-01-2011, 09:03 AM   #2
blktransam's Avatar
Trader Rating: 59 (100%+)
your disks could be glazed...take them off and clean them or replace them, also make sure the batteries are charged for the reciever. and make sure the brake servo is pulling the full amount you want.
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 01-01-2011, 09:12 AM   #3
18SS's Avatar
all of that has been checked off the to do list
i no its different with every car but if someone with a D8T could take pictures of there breaking set up and there pads
that would be a big help and i could work off that
Old 01-01-2011, 09:16 AM   #4
nitroexpress's Avatar
If you have lightly sanded your disks, then maybe your pads are gapped too wide. I never go by a spacing given in the manual. As long as they are not dragging, run the pads as close as possible.
nitroexpress is offline   Reply With Quote
Old 01-01-2011, 09:16 AM   #5
blktransam's Avatar
well thats the only 3 things that could cause them to not "work"...or you have a weak throttle/brake servo?
-Ryan Klemme
Old 01-01-2011, 09:17 AM   #6
18SS's Avatar
what do u mean bi that "nitroexpress"
Old 01-01-2011, 09:23 AM   #7
If you tighten the two screws that secure the pads (front and back brakes) you will lock the pads onto the disk. Then just backoff until there is no drag.
Old 01-01-2011, 09:29 AM   #8
What servo are you using? Are you sure your battery is fully charged and in good shape?[/
Old 01-01-2011, 09:30 AM   #9
18SS's Avatar
oh ok i understand that
but the main problem is
i have all the set it nicely
but say im hittin a jump at the track then land it and theres a nice tight turn right at the bottom of the landing
im not going to be able to break strong enough to be able to pull a fast u-turn to keep the lead. i would have to land the jump hit the breaks and my truck will still be moving pretty fast while i am breaking before i can make the turn.
or say
im siting down with my car
and im pushing it back and forth
if i hit the breaks it will dip down and slow down but i can still push it with my hands
Old 01-01-2011, 09:31 AM   #10
18SS's Avatar
they r hiteck servos
and yes battery is fully charger
Old 01-01-2011, 09:33 AM   #11
or say
Well, obviously everything is not nice because I and others can lock up the brakes in most situations. Gap, battery, weak servo. That's my guess.
Hitek makes lots of servos, which one?
One other thought. Have you changed your EPA setting for the brakes? Have you tried increasing the brake EPA (assuming it's not at 100%)?
Old 01-01-2011, 09:38 AM   #12
18SS's Avatar
well at the moment i do think it is the servo but i dont really no
im going to change it for a high tourk servo i do think that mihgt really help my problem
Old 01-01-2011, 09:44 AM   #13
jmaxey51's Avatar
what hitec servo do you have? i found with my old D8T you need a pretty strong servo to get it to stop.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 01-01-2011, 09:50 AM   #14
18SS's Avatar
oh its not top of the line more bottom end due to the fact i spent my money on a pip engin and steering servo
Old 01-01-2011, 09:58 AM   #15
Trader Rating: 68 (100%+)
The Hitec 7955 will get the job done and last you for several seasons.
Also Savox has some nice fast/torque servos at a reasonable price.
Greg B is offline   Reply With Quote
i need some help to pick a truggy zenbonzakura Nitro Off-Road 26 11-05-2010 09:43 PM
need help choosing a truggy ibmenace Nitro Off-Road 66 09-12-2010 02:00 AM
help help racing help slasher man Nitro Off-Road 19 12-16-2009 11:45 PM
Help selecting a Truggy and motor please. Mickey Silver Canadian R/C Scene 6 07-01-2009 09:29 AM
