Old 12-30-2010, 02:21 PM   #1
jammin32j's Avatar
Default check this out
http://www.absolutehobbyz.com/produc...oducts_id=4072
I have one and it works great. I glued up 24 tires and they all look factory glued, and I did it in half the time.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 12-30-2010, 02:32 PM   #2
KWT-NITRO's Avatar
sounds good specially for someone who really sucks at gluing tires, my last attempt ended when i splashed CA into my eye
how does it work??
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 12-30-2010, 02:52 PM   #3
jammin32j's Avatar
There is a top plate and a bottom plate. You sandwich the tire between them and then fold out the cams and it pulls the tire away from the rim just enough to get the glue in there.
VP Pro, Agama
Jeremy Davis
Old 12-30-2010, 02:53 PM   #4
It works by pulling the full 360 degrees of tire bead back at once. Allowing you to glue the entire bead at once. There are many adjustments on it to fit any combination of tire and wheel manufacturers(because they are all slightly different). It works really well. I watched my brother glue up 24 tires in under an hour(prep to finish). As a note, this model only works on 1/8 buggy tires. Model for other tires are soon to be released.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 12-30-2010, 02:57 PM   #5
KWT-NITRO's Avatar
thanks for the info,
just a question, do you guys dremel the tire/wheel before gluing??
also when using this gluing device, you still have to use rubber bands or not??
cheers
Ali
Old 12-30-2010, 03:22 PM   #6
jammin32j's Avatar
cheers
Ali
Yes I still dremel the tire and rim. I still use the bands but I put them on after I glue the tire and pull it from the fixture. What I do is apply the glue to the tire and then slowly release the cams. Be careful no to get glue on the top plate when you slide it out. Then I pop the tire (glue side down) on a paper towel just to get the excess glue off. Then I put the tire band on and let that side dry before I glue the other side.
VP Pro, Agama
Jeremy Davis
Old 12-30-2010, 03:25 PM   #7
Default Love mine
I am really happy with mine not only is it much easier to glue tires it also makes a better bond. I don't have to keep regluing tires after every race.
I still use the rubber bands to press the tire to the rim while the glue dries, but no more pulling the tire back and gluing an inch at a time not to mention gluing my finger to the tire.
popsrocket is offline   Reply With Quote
Old 12-30-2010, 03:42 PM   #8
KWT-NITRO's Avatar
great info, thanks alot guys
Old 12-30-2010, 03:49 PM   #9
how does it work??
Haaaahaha. The vapors alone make my eyes water a lot. How did your eye turn out?
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 12-30-2010, 03:51 PM   #10
Racecrafter's Avatar
Trader Rating: 25 (96%+)
This RWD unit has been around for a couple of years. I know a few shops including "The Speed Shop" use it.
http://www.russwernimont.com/RC-Racing-Parts_c_9.html
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 12-30-2010, 04:00 PM   #11
didrace's Avatar
Default Help me please on this one..
guys please give me some help here..i always have problems when i glue my tires..they always come off from the first minute and i use high performance glues such as AKA and all my tyres and wheels are AKA and proline.
someone told me about the dremel think but i am not sure how to do it..
can someone give me the steps so that i wont have my tire getting unglued..
btw are these two systems available in europe? or can they get shipped in to europe?
help will be appreciated.
Thanks!!
didrace is offline   Reply With Quote
Old 12-30-2010, 04:00 PM   #12
Suspended
Trader Rating: 37 (100%+)
Ive had one of these for awhile now and it works great!
PERMA BANNED FOR TALKING SHIT TO A MOD
BoysMakingNosie is offline   Reply With Quote
Old 12-30-2010, 04:09 PM   #13
Suspended
Thanks!!
Im sure you can get one shipped to you if not let me know and I will get you one and ship it at your expense..(I race with them alot)
I dont dremel my rim I use Alcohol to clean it(Tire&Rim) and cut any odd rubber off the tire.
I also use Loctite Professional Super Glue-- I get it from my Hardware store in town(WORKS GREAT)
http://www.amazon.com/Loctite-Produc.../dp/B004E2QBWG
Old 12-30-2010, 04:15 PM   #14
pantera nitro's Avatar
i don't dremmel either but i do use some really really fine sand paper on the rim as i find a slightly dull edge adheres to the glue/tire better.
then it clean thoroughly and glue.
MP9-TKI2/O.S. 21XZ-B V-Spec Speed
RC8T-CE/MG66X
RC8B-e/Hobby Wing
RC King Hobbies - onlinerc.com.au - Pro-Spec Race Bearings
pantera nitro is offline   Reply With Quote
Old 12-30-2010, 04:17 PM   #15
Thanks!!
Fresh glue: We spend enough on tires, is it really worth it to ruin a brand new set (or 2 or 3) using old glue? Just spend the extra few bucks and get a new bottle.
Also, make sure your hands are clean before gluing. grease from that burger and fries will probably weaken a glue bond.
TPJ International
071crazy is offline   Reply With Quote
==You like stickers?--Then check this out!!== WYLDTHING R/C Items: For Sale/Trade 71 01-31-2010 10:34 AM
Check this out... Trans Am bodies on touring cars PaintingRoly Florida Racing 312 03-22-2009 07:28 PM
wow, check this out skypilot Northwest Racers 62 11-24-2008 04:16 PM
CHECK THIS OUT 1/36 Micro-T t9dragon Micro and Mini Scales 283 04-26-2007 05:24 PM
