Old 12-29-2010, 06:11 PM   #1
Trader Rating: 26 (100%+)
Default Truggy pulls when acceletating
Hey all... Newbie here. I got a Nitro Truggy running a .26 motor and when I go from idle to full throttle the truggy tends to spin the wheels and pull to the left. Is this common because of the power or is there something not right with the differential. How can I determine what is wrong and fix it. Kinda makes it hard to gun it coming out of the corners and keep it online for that triple jump
SDelaney is offline   Reply With Quote
Old 12-29-2010, 06:28 PM   #2
Led Finger's Avatar
Default diff oils
I would say the diff oils need to be changed.. possibility a shock oil/ or binding in the shocks? thats where I would start.. or be easier with the trigger finger
Mugen MBX6r USA - Mugen MBX6r ECO USA - RC8Te - Baja SS - B4.1 - Erevo Brushless
Led Finger is offline   Reply With Quote
Old 12-29-2010, 06:49 PM   #3
jmackani's Avatar
Trader Rating: 14 (100%+)
Check your drive shafts and bearings, that is normally a sign of something seized up.
jmackani is offline   Reply With Quote
Old 12-29-2010, 06:55 PM   #4
Sein's Avatar
+1 If one of your bearings on one side of the diff is seized it will pull to the other side. You should just take the truck apart to check and replace everything that is needed.
Ronnie Senters/Glory2God Racing
D8T-Alpha A352/D812-Alpha A852
Team Hotbodies Hawaii
Sein is offline   Reply With Quote
Old 12-29-2010, 06:58 PM   #5
vwduud's Avatar
Trader Rating: 45 (100%+)
1/8th scale vehicles eat wheel and diff bearings.
Check regularly and replace as needed.
Jim Brown
Tekno EB-48.4, ET-48, Rx8 G2, 1900kv/2000kv, Savox 2274/2273, SMC, 4PX
Sponsors: Tekno, RC Crew Chief (chassis tuning S/W)
President of SCR (just outside New Orleans) - https://www.facebook.com/scr.raceway
vwduud is offline   Reply With Quote
Old 12-29-2010, 06:59 PM   #6
houston's Avatar
Trader Rating: 91 (100%+)
usually notched drive cups
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-29-2010, 07:37 PM   #7
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Makes perfect sense
Kevin Murphy
Associated B5m/Reedy
AP Custom Paint/Kal-Gard/
Slimsh8t is offline   Reply With Quote
Old 12-29-2010, 11:38 PM   #8
merdith6's Avatar
Default Also
Check the center diff oil. If it is too thin the truck will torque steer on acceleration....Unload too much to the front wheels...
I say sure, check all that other stuff, but change the center diff oil to say 15,000....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 12-30-2010, 04:39 AM   #9
Jerseyboy's Avatar
Firstly make sure your drivetrain is loose. As mentioned in earlier posts, check bearings and diff oils. Thicker centre diff oils will make the truck push more nad thinner oil will pull more.
If its pulling to the side it could be bearings. Also swop wheels just for fun.
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 12-30-2010, 08:11 AM   #10
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
What Truggy? How much runtime (A few tanks, a gallon, a few gallons of fuel) is on it? Is it a RTR straight out of the box?
What diff oils do you have in it? Shock oils? Does it "roll out" straight when coasting? If you sit it on something with the wheels off the ground, engine off, does everything spin freely?
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 12-30-2010, 08:44 PM   #11
It's a Hot Bodies Lightning. I got it used so I don't know all the answers. I did just put new Losi 60 shock oil in the shocks (still seem to soft though). I have run maybe 1/2 gallon of fuel in it.
I will have to check and see, but if memory serves me the rear left doesn't spin as free as the others. I will check and repost. It rolls straight and on concrete there is no noticeable pull.
Old 12-30-2010, 08:47 PM   #12
pitpop's Avatar
check the hub bearings
also, if the dog bone pins have worn out the drive cups, it will pull to one side
those are the two most prevalent causes of pulling to one side
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 12-30-2010, 08:48 PM   #13
Yes, the left rear wheel does not spin as free as the others and it also appears the dogbone is bent. Could that be it. I guess that should be my starting point.
Old 12-30-2010, 11:51 PM   #14
pitpop's Avatar
There you go
