Old 12-28-2010, 12:25 PM   #1
tq_racing's Avatar
Trader Rating: 65 (97%+)
Send a message via AIM to tq_racing Send a message via Skype™ to tq_racing
Default losi 1.0 vs. 2.0
so what all is different between the 1.0 and 2.0?
i know the towers and the chassie and tank but what else?
Jason Littlejohn
JL GRAPHICS for all your paint & vinyl needs!!
www.facebook.com/jl.graphics1
tq_racing is offline   Reply With Quote
Old 12-28-2010, 01:00 PM   #2
boomgagem's Avatar
Trader Rating: 45 (100%+)
Send a message via AIM to boomgagem
Radio Tray, Turnbuckles, Shock Towers, Chassis, driveshafts
I think the diff cases are different too, I could be wrong though
Team Terribles Georgia State Rep
Team Losi Racing
Pineland RC Race Director
boomgagem is offline   Reply With Quote
Old 12-28-2010, 02:09 PM   #3
alphaplus-guru's Avatar
rear a-arms, the outer hinge pin holes need drilled to fit the 2.0.
front a-arms are thinner on the 2.0, but they fit the 2.0
outdrives are differnt, but still work on the 2.0 obvously.
the 1.0 ball studs are smaller but you can take them off the 1.0 and use on 2.0...(along with the ball joint) they are alot more bulky.
rear outer hinge pin brace becomes 3/3 not 3/2 anymore.
Ask me anything about alpha plus series engines. z852(green), F850(red), S852(orange)
alphaplus-guru is offline   Reply With Quote
Old 12-28-2010, 02:19 PM   #4
Trader Rating: 50 (100%+)
-The 2.0 body is different than the 1.0
-Rear diff gear mesh is adjustable w/ shims
-Brake pads are different material, and alot better!
Pre-Loaded
ForwardBite is offline   Reply With Quote
Old 12-28-2010, 02:25 PM   #5
tq_racing's Avatar
ok so i am looking to get a 1.0 in a trade. i already have a 2.0 chassie, tank, and radio tray. so if i took all the 1.0 arms and stuff off and put them onto the 2.0 chassie then everything would fit? also if i bought 2.0 shock towers. then that would pretty much be a 2.0 then?
Jason Littlejohn
Old 12-28-2010, 02:52 PM   #6
Yes, if you bolt the 1.0 front, rear and center onto the 2.0 chassis, you will be good to go. I wouldn't worry about the towers unless you're worried about looks. You may also need a longer rear center driveshaft.
Pre-Loaded
Old 12-28-2010, 02:56 PM   #7
tq_racing's Avatar
great thanks
Jason Littlejohn
Old 12-29-2010, 05:43 AM   #8
neobart's Avatar
Yup the only real performance difference between a 1.0 and 2.0 is the chassis.
Let me know if you want some 2.0RR towers, I have a lightly used set that I don't use.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 12-29-2010, 06:06 AM   #9
Davidka's Avatar
Trader Rating: 75 (100%+)
The 2.0 chassis is a touch longer in the rear than the 1.0 so you may need a longer rear center CVD, should not be very expensive though.
Losi 8ight 1.0 and 2.0 parts interchangeability brofroe Electric Off-Road 10 12-28-2009 08:25 PM
Losi 8ight 1.0 vs 2.0 orcusomega Nitro Off-Road 8 09-30-2009 10:00 AM
