Old 12-27-2010, 03:08 PM   #1
wannarace's Avatar
Default Anyone local that can help?! Nitro Issue!
Need someone local to help me crank over my new Novarossi 4-plus...I consider myself a nitro noob and even though seemed to have setup everything correctly it seems like my blue top OFNA starter box is smoking up the wheel trying to get the flywheel to turn...I searched the threads and tried everything...
wannarace is offline   Reply With Quote
Old 12-27-2010, 03:10 PM   #2
losi_racer's Avatar
Trader Rating: 25 (100%+)
read this.
http://www.rctech.net/forum/offroad-...eak-bible.html
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 12-27-2010, 03:11 PM   #3
deweyharding's Avatar
Trader Rating: 39 (100%+)
pre-heat the engine with a heat gun.
EZ Customs Team Driver
VP-Pro USA - www.VP-Pro-USA.com
Werks Racing engines - www.werksracing.com
Werks racing fuel - www.werksracing.com
deweyharding is offline   Reply With Quote
Old 12-27-2010, 03:15 PM   #4
wannarace's Avatar
Thank you for the replies...I've done a lot of research prior to my first attempt to crank her over...I preheated the engine with a temp gun to 210 degrees, I primed the fuel lines and even backed out the plug a smudge....nothing can get this motor to break the pinch and start up...the rubber wheel on the starter just smokes up...
Old 12-27-2010, 03:16 PM   #5
wannarace's Avatar
I even turn the flywheel all the way back to the opposite direction so it has momentum going before it hits the pinch...still no luck.
Old 12-27-2010, 03:18 PM   #6
losi_racer's Avatar
what most likley has happened is the piston is stuck at TDC, use a flat head screwdriver and pry it pass tdc, once its at bdc preheat to 200 degrees. the ofna box should not have any issues turning the plus 4 over. what batteries are you using in the starter box?
Old 12-27-2010, 03:20 PM   #7
wannarace's Avatar
LIPO 4s
Old 12-27-2010, 03:20 PM   #8
losi_racer's Avatar
LIPO 4s
your preheating the engine to 200 degrees correct?
Old 12-27-2010, 03:22 PM   #9
FLHX1550's Avatar
Make sure you arent hitting the chassis on the wheel also. Just a little drag there and it will drag it down and not start the engine.
If the piston is stuck coming to top deap center, make sure you are heating the engine and not just the cooling head.
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 12-27-2010, 03:26 PM   #10
nitroexpress's Avatar
Make sure it's not stuck at TDC (top dead center), heat it and start it with the glow plug loose. Once running, tighten the plug.
nitroexpress is offline   Reply With Quote
Old 12-27-2010, 03:28 PM   #11
wannarace's Avatar
Yes, got it unstuck from TDC for the 3rd time...tried it again and bam...stuck
Old 12-27-2010, 03:30 PM   #12
wannarace's Avatar
Done and done...still nothing....I even took the starter box guides off thing maybe Im not lined up correcty...so Im looking from up to as the wheel hits just the flywheel and still nothing...it just grabs at the pich and gets stuck
Old 12-27-2010, 03:31 PM   #13
wannarace's Avatar
I loosened it up a bit...but let me loosen it up some more.
Old 12-27-2010, 03:37 PM   #14
hambone's Avatar
Make sure it's aligned properly. Check rubber wheel to chassis opening with the engine off the car. The smallest amount of misalignment added to the pinch of a new engine will smoke even the ofna truggy box.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 12-27-2010, 03:37 PM   #15
SteveP's Avatar
I'm heading to West Coast RC right now. If you want to bring your car there, I'll get it fired up for you.
SteveP is offline   Reply With Quote
calling all FUTABA 3PK users..... JayBee Radio and Electronics 1312 01-25-2015 07:57 AM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 09:03 AM
Tuning Guide for Nitro? K_King Electric Off-Road 6 02-16-2007 03:51 PM
Trinity G4 - Team Magic G4 E-Type puma1824 Nitro On-Road 3128 10-04-2005 04:17 AM
