Old 12-24-2010, 01:25 PM   #1
TXRC8racer's Avatar
Trader Rating: 19 (100%+)
Default Best way to improve lap times??
Im really looking to step up my game for the 2011 racing season in 1/8 offroad. What do you recommend in improving one's lap times on the track?
Is it understanding car/truck setups more? And able to adjust your car/truck to track conditions.
Equipment i.e Radio system, tyres, car brands?
Or is it practice?
Last year I did not do alot of practice just ran a race prolly once a month either a local race or a RC Pro Series event. I would like to get in practice at least once a week to get me where I want to be in the Open class. What is some of your practice schedules in being really competitive in a Open class, once a week, twice a week, every other week etc..etc...
Lance Plant
Sponsors: Team Associated~Reedy~LRP~Pro Line~Avid RC~Airtronics~Werks Racing
TXRC8racer is offline   Reply With Quote
Old 12-24-2010, 01:33 PM   #2
Practice, practice and more practice and remember slow is fast, every time you get marshalled you lose an average of 7 seconds.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 12-24-2010, 01:59 PM   #3
Get a good setup , drive consistent & practice practice practice . Have a good tire selection cause IMO tires are 85 % of a good setup .
romax is offline   Reply With Quote
Old 12-24-2010, 02:01 PM   #4
ScottyM's Avatar
Trader Rating: 27 (100%+)
Don't crash.. Push your car as hard as you can in practice until you crash, then back it off just enough during the races, or change the set up to allow you to push it harder..
As far as equipment goes a quality Radio is way more important then most people realize.. Well having it and being able to adjust it to help you out.
I think most all car brands are farily level, with certain brands lending more toward certain driving styles. Motors are in the same situation, comes down to what you like and can afford. Tires are a big key to set up the right tires or wrong tires can make or break a set up.
Ability goes a long way too.. I've seen guys come in that have never raced and spank butts, and I've seen guys that spend tons of time setting up and tweaking get spanked.
Set up is a big factor, and the right set up with the right tires can make a car stick like glue, where the wrong set up or wrong tires can cause you to over drive the car..
But all in all it comes down to practice, being IN-TUNE with your buggy/truggy and knowing when something is right or wrong, and knowing what it will or won't do is only learned by spending the time on the stand and behind the trans..
Hope my rambling helps, and good luck to you in the 2011 out door season. I know I am looking forward to mine..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 12-24-2010, 02:10 PM   #5
Yes a good radio is the most under estimated items on this hobby.
Rui Almeida
Hamilton, Ontario
CANADA
Old 12-24-2010, 02:13 PM   #6
CanadianEH's Avatar
I would say practice is a big part of it.. But take sometime when your at a race. Watch some of the fast guys lines.. And pay attention to the way they navigate the track. Also it helps to do a walk around the track an look at it from a different perspective. But most of all practice practice practice...
www.johnnyboy.ca
www.darksidedesigns.com
www.xxxmainracing.com
CanadianEH is offline   Reply With Quote
Old 12-24-2010, 02:29 PM   #7
TXRC8racer's Avatar
My equipment is good...good as any... I have always bought what I thought was the best out there in my opinion
My Equipment:
RC8TCE/RC8B
3PKS Radio Spektrum 2.4 HRS module
Werks Motors and pipes
Hitec 7955 Servo's
ProLine Tires
Jconcepts Bodies and Wings
The base setup are from Ryan's Roar set ups but I adjust a little from them..
Lance Plant
Old 12-24-2010, 02:31 PM   #8
Cappy's Avatar
Trader Rating: 14 (100%+)
SLOW DOWN !!!!!
Fast is Slow and vice versa.
Start slow and build speed/momentum
Being consistent is key
If you don't believe me ask any local fast guy
Tekno EB48.3 RX8 Gen2 T8 1900 19T..
Tekno ET48.3 RX8 Gen 3 T8 2000
Tekno |Sweep | Dialed Inc | Boca Bearings | Mels Shells
SLOW THE F%&# DOWN so you can go fast !!!
Cappy is offline   Reply With Quote
Old 12-24-2010, 02:33 PM   #9
SteveP's Avatar
All the advice about practice is spot on. THEEEEE number one mistake is see novice drivers make is carrying too much speed into the corner and blowing the fast line. Each time that happens, even if you don't need to get marshaled, you lose up to half a second. If you multiply that by the number of turns at your track, then it adds up quickly. The "fast" guys always hit their braking points and take each corner tight. They're not getting on the throttle too early and pushing wide coming out of the corners either. They wait until the car rotates enough that it's pointed in the right direction, and THEN get on the throttle. That's why you'll always hear "slow is fast." Going way too deep into the corner and throwing dirt all over the place may look exciting and fast, but the truth is, a more controlled approach to each corner and allowing the car to roll through the apex on a tight line beats the dirt burners all day long. If you can work on controlling your pace and smoothing out your driving style, you'll be much faster.
SteveP is offline   Reply With Quote
Old 12-24-2010, 02:34 PM   #10
imaxx21's Avatar
Send a message via AIM to imaxx21
there's no substitute for track time.
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 12-24-2010, 02:42 PM   #11
everything stated above. I run indoor carpet in winter which does help. Also have a tc3 with drift tires. When weather is good, I am strictly dirt.
morkendi is offline   Reply With Quote
Old 12-24-2010, 03:17 PM   #12
ChrisL's Avatar
You need a coach to work with you. If you practice wrong you will learn wrong. Would make a great magazine article!
ChrisL is offline   Reply With Quote
Old 12-24-2010, 03:21 PM   #13
j_blaze14's Avatar
Trader Rating: 34 (100%+)
more practice
slow down a bit, ever have your tune off? your fat motor won't clear out but no one passes you? and you pass all the upside down guys and your laps are faster? less power/clutch helps. when i drove sc class i had my speedo dialed way down on punch and had to wait for the power and got it around pretty good that way.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 12-24-2010, 03:34 PM   #14
TXRC8racer's Avatar
Im stepping up from sportsman to open I signed with Werks Racing this winter but the rule with RC Pro Series if you have % of engine or chassis sponsorship you must run in the Open class. I finished 12th in national points in sportsman arena truck and like 17th in buggy. I qualified in every A main in truggy but one race. Im just really looking at what all you Open guys are doing to be competitive..Is it the weekly practice that keeps you on your game?
Lance Plant
Old 12-24-2010, 03:40 PM   #15
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
practice practice practice, dont stick to one scale of racing.....mix it up and try some 1/10 offroad or 1/12 carpet........keep practicing and be very serious about it in a positive way....dont forget to be courteous to others and have fun along the way!
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
How long did it take for you guys to get better? mikesd1980 Nitro Off-Road 75 10-31-2010 02:30 AM
I need faster lap time banji Nitro Off-Road 66 01-03-2010 12:04 AM
To all rookies: Step-by-step article on how to go racing OTE_TheMissile Rookie Zone 42 07-09-2008 10:16 PM
which servo's are the best for tc nitro neil Electric On-Road 49 12-02-2007 05:06 AM
