Old 12-29-2010, 04:03 PM   #91
cordarrow's Avatar
Trader Rating: 17 (100%+)
I had no idea they hit the brakes so often.
We have some pro guys at our track....I often watch only their transmitter ...I was amazed as well. Hundreds of times per lap...
cordarrow is offline   Reply With Quote
Old 01-07-2011, 12:39 AM   #92
When you know that there are 3 points on the track that you make mistakes, do you repeat those points again and again explicitly or do you just run the whole track and just try to drive better/slower at those points?
Jaap is offline   Reply With Quote
Old 01-07-2011, 02:44 AM   #93
Bigedmond's Avatar
Trader Rating: 18 (100%+)
I will normally run the section a couple times in a row to get a feel for it, then do a full lap trying to add what i learned. Then i would run a couple more laps trying to get it consistent. After a tank or 2 of doing that, i try to pick up the pace. But being consistent is far more important then shaving a 10th here and there. You have to look at all wrecks that require a marshal as 10 second mistakes. Even if you slow down, a section wont cost you that much time.
Bigedmond is offline   Reply With Quote
Old 01-07-2011, 02:57 AM   #94
I just want to carry out a constructive practice for once and I never do because everytime I go to the track I start racing around with a couple of friends and I forget to actually practice! I thought of doing two laps and then stop and think about where I went wrong and try to understand how to drive at those points.
Also because I never see the good drivers around for practice I don't know if I am doing something wrong at certain points of the track or if my setup isn't tunned enough to take the track at those points...
Old 01-07-2011, 03:16 PM   #95
phaqu22's Avatar
Trader Rating: 31 (100%+)
Where should braking points be entering a corner? How can I pick up corner speed?
Should the Brake be applied way before the corner and roll through or start applying gas through the corner?
TLR
phaqu22 is offline   Reply With Quote
Old 01-07-2011, 03:27 PM   #96
Suspended
Trader Rating: 202 (96%+)
all that really depends on set up, diff oils, sway bars, ride height, shock oil, tires,....ect, many awnsers for your question
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
How long did it take for you guys to get better? mikesd1980 Nitro Off-Road 75 10-31-2010 02:30 AM
I need faster lap time banji Nitro Off-Road 66 01-03-2010 12:04 AM
To all rookies: Step-by-step article on how to go racing OTE_TheMissile Rookie Zone 42 07-09-2008 10:16 PM
which servo's are the best for tc nitro neil Electric On-Road 49 12-02-2007 05:06 AM
